what gas consumption reading per engine could be logical? >
Old 09-04-2007 | 08:41 PM
jeff32's Avatar
Default what gas consumption reading per engine could be logical?
15 gal/hour per engine for example at 5000 rpm... does that make sense to you?
That is what my floscan tells me but I feel it must be more than that...
Any idea on that?
jeff32 is offline
Old 09-04-2007 | 08:44 PM
chuckbeecher
From: Anywhere from the Laguna Madre to JAX and beyond
Which engine and h.p.?
Type boat?
chuckbeecher is offline
Old 09-04-2007 | 08:45 PM
check the other thread.
Rippem is offline
Old 09-04-2007 | 08:46 PM
jeff32's Avatar
454-485 hp in F35-7 1989
jeff32 is offline
Old 09-04-2007 | 08:48 PM
A good rule of thumb is 10% of Hp @ Wot = GPH.
tigweld is offline
Old 09-04-2007 | 08:50 PM
chuckbeecher
From past experience I would say it is burning 46-54 gph.
The above would be correct if near max rpm.
My 502/465s burned right at 47 gph wide open throttle.
They were carb motors..efi should be a tad more effecient.
Old 09-04-2007 | 08:55 PM
jeff32's Avatar
46-54 per engine or for both?
jeff32 is offline
Old 09-04-2007 | 09:05 PM
true, but most often under that real world. I've seen it and verified it more than once.
my 350 HP 454 mags would burn ~ 28 GPH WOT (accurately calibrated (<2%) Floscan)
Rippem is offline
Old 09-04-2007 | 09:10 PM
no, that's why I told you in the other thread YOU'RE READING 1/2!
your real GPH is about 30 GPH WOT on those 385's
been there done this! I just can't tell you off the top of my head after a few years and on my 5th 12 hour night shift which switch to change!
call tech! they are fantastic and will give you the answer!
Rippem is offline
Old 09-04-2007 | 10:14 PM
If you are making 450 HP at 5000 RPM. My math says at .5 lbs of gas per HP you will use 225 lbs divided by approx 7 lbs per gallon = 32 gal per hr per engine. The FloScan should be reading in range of 29-35 gal per hour per engine
BenPerfected is offline
