Fuel Gauge Issues.
Old 09-05-2007 | 08:36 PM
Default Fuel Gauge Issues.
I have a Gaffrig fuel gauge in my Baja. It reads empty all the time. I checked the connections at the sending unit and I have 9.9V there and at the gauge. I disconnect the center wire from the sending unit and I still have 9.9V on the wire. I wouldn't expect this because there is no path for current to flow so I would expect 12V on the wire now. The gauge still reads 9.9V.
What's the best way to check out the gauge by itself? I want to make sure it is good before I attempt to take the sending unit out.
27shooter is offline
Old 09-05-2007 | 08:41 PM
Elite Marine's Avatar
Sounds like you have a voltage issue. I expect that the sending unit is simply a resistor and may be stuck. I will try to get a hold of the factory to try and help, but I'm stuck in a seminar all day tomorrow.
You could also call Gaffrig direct at 224-569-2900
I will try to get the answer and post it as it would be a nice troubleshooting tip to have.
Elite Marine is offline
scottie150
8
05-05-2008 09:16 PM
Steve_H
4
02-03-2007 11:58 PM
JGB
6
04-19-2004 10:54 AM
JROMY
2
07-23-2003 07:29 AM
27 FOUNTAIN
5
04-14-2002 12:20 AM
