2001 312 Fastech handling problems? >
Old 09-06-2007 | 10:48 AM
K-MAN's Avatar
Default 2001 312 Fastech handling problems?
Does anyone have a false sense of security when driving there
312 Fastech? I have this uneasy feeling when I drive my 312,
like its about to roll and or bounces all over the place. Or could
it be that I'm not use to the step hull design yet! Any thoughts
or ideals on what I can try?
K-MAN is offline
Old 09-06-2007 | 11:01 AM
I'd say it's the stepped hull. It takes some getting used to. First time I ever drove Axa's 353 it was kind of wierd. But, it is just different, not wierd.
ThirdBird is offline
Old 09-06-2007 | 11:07 AM
t500hps's Avatar
21 and 42 footers
Mine was stable under 70...after that it felt real loose on the water. If the props are spinning in try changing them to spin out.
t500hps is offline
Old 09-06-2007 | 02:03 PM
LV's Avatar
LV
yes it is kind of loose, I think the main reason it feels diff, is the lack of bow lift on the 312's, it can get a little scary, it gets better with seat time, how long have you had it ?
LV is offline
Old 09-06-2007 | 02:10 PM
K-MAN's Avatar
Default Since September 2006
Picked it up with 160 hours, it looked like it just came from the
factory.
K-MAN is offline
Old 09-06-2007 | 04:56 PM
axapowell's Avatar
Where To
Sounds like a trim issue to me. You are either over trimming or under trimming. Not enough and it will bow steer. Too much and you will loosen it up too much.
I changed my prop rotation this year to spin in and it helped with the bow steer, but I am running a 353 with 5 blade Maximus props. It created more bow lift and the feels PERFECT now. Although you do give some up around the dock. A little getting used to it and it's not too bad.
Try a few different trim positions and see which performs best and which handles best. Go slow with the trim, it can be a very small sweet spot that you are searching for!
Dave
axapowell is offline
Old 09-06-2007 | 08:14 PM
BL6
What kind on water/ conditions give you the most problem. How do you like to trim it out & set tabs when you are underway?
BL6 is offline
Old 09-06-2007 | 09:08 PM
K-MAN's Avatar
Default On flat water she goes like hell and easy to handle!
On wide chop she's a *****! Large rollers 2 to 3 plus waves real bad. In real tight chop, solid and even kind of fun and managable. I've tried all types of settings with the trim tabs
and drives. Some days I win and some days I lose.
K-MAN is offline
K-MAN
07-23-2008 10:04 AM
JEFF CHRZANOWSKI
4
08-23-2007 11:56 PM
K-MAN
07-14-2007 06:22 PM
LV
03-28-2007 10:43 AM
Crazyhorse
07-19-2006 12:40 PM
