overheating and water in the bilge
All this talk of ethanol and phase seperation, made me go out today to try and burn some old fuelo and my tech wants the tank low for winterization. Running the twin 496HO's hard, all is well but all of a sudden, an alarm. Port engine sputters and I shut them both down. The port side was running 220?+/-. Let them cool down to about 180 and fired up fine but in a few seconds the alarm was on again. Decided to limp back to the lift on the starboard only. Put her on the lift and gave it a few hrs. to cool down. Once cool, dropped back in the water. Fired up fine but no water exiting the exhaust and bilge came on. Opened hatch and water being dumped right into the bilge. I'm assuming a hose came loose or ripped but engine too hot to try and trace. I'm not going to be able to get back to it until next weekend. It's tight w/ twin 496HO's in a 33 Baja Outlaw. Any advice? Should I be able to repair/replace w/o pulling too much stuff off? TIA.
Please, please, please, I have a bunch of relatives coming this weekend from Europe who want a ride. Moreover, it'll be a real pain to get it off the lift, down to the ramp and on the trailer on only one motor.
Yeah only when it's running. Thank God. And no flush attachment. ???
There are a bout a dozen clamps on the pressure side of raw water. You better go and check before weekend. Water pump is low on starboard side of engine, hose connect to bottom of exhaust manifold and up to cooler across back of motor. From the cooler hose leads down again to oil cooler and exhaust manifold than lower still to fuel cooler. Hose from fuel cooler leads to front of engine and up to heat exchanger.
Hope for an easy one. I will pray for you.
Jim
Jim
