Shallow Water!! >
Shallow Water!!
Shallow Water!!
Old 09-10-2007 | 12:04 AM
Default Shallow Water!!
While at the river I hit a shallow spot ran over rocks, chewed up my prop, and skeg. I notice now when I rev the motor, it makes this high pitch rattle noise. I have a 91 Hallett 210s with a 454 and bravo I outdrive. Any advice would be helpful, I'm new to the boating scene.
bambigular is offline
Old 09-10-2007 | 07:21 AM
t500hps's Avatar
21 and 42 footers
Sounds like you broke some teeth inside the drive.....it neds to come apart, the longer you run it the more damage your doing to the internals.
t500hps is offline
Old 09-10-2007 | 09:27 AM
boatn70's Avatar
doesnt sound good, is that with the drive down and with a new prop on it?
boatn70 is offline
Old 09-10-2007 | 10:21 PM
yea, with a new prop and drive all the way down, I hit the rocks at about 45mph.
Old 09-11-2007 | 05:51 AM
Payton's Avatar
Charter Member #927
Check with your insurance company.
Payton is offline
Old 09-11-2007 | 10:07 AM
boatn70's Avatar
i should clarify....
after hitting the rocks, you now hear the noise...is that with the drive down and new prop?
i was just thinking about balance of damaged prop (probably wouldnt do it) and if the drive was up you will always get some noise.
jsut thinking outloud....
insurance!!
boatn70 is offline
Old 09-11-2007 | 05:08 PM
Payton's Avatar
Charter Member #927
I hit some rocks, with my props, as I pulled away from a sea wall. My gimble ring broke apart 10 miles down the lake. My insurance company paid to have both drives taken apart and checked. every shaft in themwas also bent. They rebuilt the drives, gimble and props. I only paid my deductable.
Payton is offline
drpete3
08-20-2008 02:26 PM
jeff32
09-03-2007 10:20 PM
dualprop
09-11-2006 02:34 PM
CrazyCat57
0
03-23-2006 09:01 AM
Audiofn
03-13-2006 09:04 PM
