Peel ply alternatives?
Old 09-13-2007 | 10:55 AM
OkieTunnel's Avatar
Default Peel ply alternatives?
Need to help a buddy repair a pontoon on his boat lift. Would like to pre laminate a small panel to go inside and match the round shape. I can't find any peel ply locally. Are their other things I can satifactorily use?
OkieTunnel is offline
Old 09-13-2007 | 12:21 PM
Google peel-ply there is a company in Washington state that carries all the air-tech stuff by the yard instead of the roll. Good service fast shipping.
excalibur32 is offline
Old 09-13-2007 | 01:21 PM
glassdave's Avatar
Neno the mind boggler
Here ya go. peel ply by the yard. theses guys to a TON of volume on a specific group of products and its tough to beat there pricing. very fast shiping to.
http://uscomposites.com/vacuum.html
08 OPA High Points Champion
glassdave is offline
Old 09-13-2007 | 05:50 PM
OkieTunnel's Avatar
Thanks excaliber. Dave, you already turned me on to US Composites and I appreciate it. I ordered some epoxy and 1708 and 1808 etc. My problem is I need something like peel-ply for the weekend and I am leaving to go to the lake in the morning. If I don't get to do the job this weekend then I guess I will order peel ply Monday and use it at a later date. There has to be some old trick like cooking spray and a trash bag or something?
Old 09-13-2007 | 08:38 PM
glassdave's Avatar
hmmm . . . what are you trying to accomplish with the peel ply? its purpose is to leave the surface of a bagged laminate with a texture to help with secondary bond on successive laminates in the schedule. are you trying to make a piece for the repair and have the texture to aide in bonding it to the old piece?
Old 09-14-2007 | 09:50 AM
Wally's Avatar
Were doomed!
If your gonna try and make a small curved piece on the outside to match the conturs of the pontoon and then trim it to fit the hole....i would do it the way ive done a few custom boom box's for cars/trucks........take either aluminum foil or masking tape and cover the area that best fits your needs....make sure to cover an area way bigger then what you need to compensate for any dripping/mess.......you can then spray a mist of Pam cooking spray as a release agent and lay your glass ontop...its gonna be a light layer....one easy trick ive done in the past is to get fleece from a fabric store...cut out the shape you want..then mix up a bucket of resin and stuff the fleece in the bucket. Make sure you have some good gloves on and squeese the fleece to help it soak up the resin....just be fore warned that fleece soaks up a good deal of resin so you may have to mix a bit more then what you think youll need! After it dries you can sand the top and start laying more layers of glass till you feel you have enough....when done it should all just peel right off and you can pull the tape or foil off the back side...
-Wally
Wally is offline
Old 09-17-2007 | 08:52 AM
OkieTunnel's Avatar
Thanks Wally. I was just going to use it to pre-make a couple layered laminate to epoxy in the back side of the hull/pontoon to give me the contour. I was going to put a screw in the middle of it and put enough force so it matched the shape then allow it to cure. Then I was going to do a normal kind of laminate on the outside that should end with more peel ply. Didn't have time over weekend so i am going to order some peel ply today.
TeamSaris
09-24-2006 06:52 PM
Hydrolift
0
08-06-2006 07:21 AM
IRONMAN
Detailing, Painting, & Fiberglass
7
01-03-2006 08:10 AM
Hot Boat
4
04-18-2004 09:48 PM
