Run Dry Impellers
Old 09-13-2007 | 03:09 PM
Clay Washington's Avatar
Default Run Dry Impellers
Has anyone ever used these?
http://www.offshoreonly.com/classifi...p?product=3366
Clay Washington is offline
Old 09-13-2007 | 03:46 PM
Haven't used them, but will probably give them a try in the Spring. I have read that water pressure may go down a little with them. Thats fine with me since I'm at 32-34psi at wot.
Griff is offline
Old 09-13-2007 | 03:52 PM
TSPM's Avatar
They don't push enough water....but they do work......your motor will run hotter from what we have seen in every application.
TSPM is offline
Old 09-14-2007 | 11:58 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Even though the impellor can last 15 min w/o water, what shape will the housing be in?
Every toasted impellor I've removed, also required the housing to be replaced do to it being melted and scored beyound use.
US1 Fountain is offline
Old 09-14-2007 | 02:56 PM
onesickpantera's Avatar
Hmmm... I usually run my boat IN WATER.
onesickpantera is offline
Old 09-15-2007 | 10:03 AM
Originally Posted by Clay Washington
I not only sell them but use them in my Twin Ilmor 625's. I've sold 100's of them without any returns or complaints. I too have read the threads mentioning the lower water psi but no one has ever given me any supporting documentation based on their own personal experiences. What I hear most is lower water psi in custom hi HP engines but normal water psi in your standard Merc & Ilmor (Ilmor uses Hardin Marine Pump) applications.
Michael Landis
MJL Performance Inc
704-905-0086
NASCAT is offline
Old 09-15-2007 | 12:32 PM
CAP071's Avatar
Awesome for Stock applications
CAP071 is offline
Boomer35
08-04-2008 09:52 AM
seahawk
5
04-25-2008 05:39 PM
Clay Washington
02-22-2008 09:31 PM
onesickpantera
10-12-2007 05:55 PM
Pantera1
01-03-2005 02:29 PM
