Bravo 3 to a Bravo 1 XR
Registered User
Little impute needed;
I have a 93 Formula 252 BR that I plan on making some drive changes to. I am dropping in a 580 hp BB this winter and I am going from a Bravo 3 (1.5 ratio) to a Bravo 1 XR (1.5 ratio). The question I have is; in its present state, when I run flat out with the Bravo 3, with 26p SS props; I am running 4650 rpm’s and 53mph (GPS), on flat freshwater. Changing only the Bravo 3 to a Bravo 1, using a 26p SS prop, will my rpm be greater than, less than or the same as the Bravo 3. My thoughts are that I would actually pull some more rpm’s simply because I will be displacing less water (i.e.: 1 prop working instead of 2) and the engine will gain more power. My buddy thinks it will be the same. Any thoughts or experience? Thanks, pax2you
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
rslick
13
06-15-2005 11:54 PM
