Why not extended tip plugs on S/charger >
Old 09-14-2007 | 09:02 AM
Default Why not extended tip plugs on S/charger
I read somewhere not to use these but i've had good luck running the AC r42ts plug. I'm I missing something?
kennyo is offline
Old 09-14-2007 | 12:05 PM
Strip Poker 388's Avatar
Rob
They say the tip can get hot and cause detination,that its stick out into the chamber. But in a bot with verymuch idleing the non will load up.
I my race car stuff i run non pro tips with the nos .
I run them at 8.5 pds on 93.
Strip Poker 388 is offline
Old 09-14-2007 | 12:10 PM
I ran extended tip plugs in my hopped up 525SC. I used NGK UR5's. Same heat range as an AC 41.
Griff is offline
Old 09-14-2007 | 02:06 PM
I couldn't run regular 42s'without loading up. the ex tip works good.
kennyo is offline
Old 09-15-2007 | 02:15 AM
articfriends's Avatar
procharger says not to run extended tip plugs with a blower,it was the only way I could keep them from fouling so I chose to ignore there advice and I have never had a detonation problem,Smitty
articfriends is offline
Old 09-15-2007 | 09:00 AM
CNC's Avatar
CNC
I was told by a Champion rep at Daytona that extended tips are cooled by the incoming air charge.
Randy
CNC is offline
Old 09-17-2007 | 09:21 AM
Talking
We all know not to follow prochargers advice, don't we.
kennyo is offline
florida gator
12
05-22-2008 10:30 PM
Cuttin Loose
1
05-15-2007 01:32 PM
bcoffield
03-30-2003 09:22 AM
Julio
09-13-2002 08:50 PM
gene
6
03-25-2002 06:03 PM
