Whipple reliability????????
I just bought a 1999 Checkmate Convincor with a 454 and a Whipple side mount on it (it is currently a Jasper reman) The owner blew a head gasket on the original engine after 200 hours and got water in one cylinder and broke a connecting rod.
The new engine has about 75 hours on it and it burned a valve last year on a speed run (78 mph on GPS according to owner). I tend to think there is either a fueling problem (pump or even octane) or the programming is too agressive from Whipple.He has not run it hard since the valve job. The engine currently runs excellent but I am a little nervous about taking it over 4k rpm. Is there software/hardware available to tweak the ECU (already modded by Whipple)? Does anyone run these things at 5000 rpm or above for any length of time?
I am familiar with forced induction automobile engines but we are only wringing them out for short bursts.
Thanks,
Bill
Thanks,
Bill
Find a dealer to work with, or call Dunstin him self at Whipple and expalin exactly what engine you have. Then, if I was you, I'd send the computer to Whipple to make sure it is calibrated the way it should be.
As for reliability, you are buying a used boat with a used engine that has been modified. Reliability is hard for us online to say one way or the other.
I am new to the Whipple product this year, and can't say enough about it. For what thats worth.
My reliability question was in regards to whether or not there are guys out there running a Whipple at 5000 rpms for any length of time and surviving. Do you keep yours pinned for extended periods with no issue?
I have held her open for say 30 seconds at a time. Then pull back, cause I am infront of who I wanted to be :-) . Mine will turn up to 5500 pushing 6 lbs.
Are you concerned about the engine or the blower itself?
All depends on the internals of the motor. I have a 540 with a whipple and run 4500rpm for extended periods. WOT is 5600 rpm @ 5lbs of boost. I hold it open for short bursts only. Not too many blower motors will be reliable running WOT for extended periods. I'd be more concerned with that Jasper motor!
Concerned about the blower causing an engine failure due to aggressive tuning or a lean mixture as well as the heat it creates even with ah intercooler that would promote detonation.
I have run mine for minuites at a time at 5400 rpm for an entire season & have had zero problems with it. I run fresh, dedicated water to the coolers. Meaning that the water from the coolers never went thru the engine, either on the inlet side or the exit side.
The key is in the coolers & the programing.
If you have the add on Whipple injectors, you need to get rid of them & go to a better setup. Not only that, if you are running the stock fuel system, that should go also.
