milkshake oil and holds 15lbs in crankcase >
Old 09-20-2007 | 09:01 AM
Angry milkshake oil and holds 15lbs in crankcase
I have a small water leak, the oil turns to milkshake after about 10 hrs, I removed the oil cooler and pressure tested it ok, and then pressure tested the block, (an old 400) and it held fine, 15 lbs. I listened closely to the engine and it runs fine.
T400's is offline
Old 09-20-2007 | 09:05 AM
how did you pressure test the block?
what color is the oil, really white or still dark? how often do you use the boat?
VetteLT193 is offline
Old 09-20-2007 | 10:40 AM
Knot 4 Me's Avatar
Check the intake manifold gasket and the riser gaskets on the exhaust manifolds.
Knot 4 Me is offline
85Baja
Do It Yourself, Boating on a Budget
6
05-18-2008 09:54 PM
85Baja
27
05-18-2008 05:47 PM
zimm17
4
05-17-2006 05:24 PM
ThirdBird
5
06-06-2005 11:16 AM
baronbob
8
05-10-2005 09:23 PM
