European CE Certification??  Mr. Cozzi, any insight? >
Old 09-21-2007 | 02:45 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default European CE Certification?? Mr. Cozzi, any insight?
Looking to get a single engine 525EFI/XR powered boat European CE Certified for export from US/NJ to Germany.
How is this done?
Who can do this?
How much does it cost?
Anyone that can do this in New Jersey?
I know about the pre-certified engines (EU662 SCi, etc.) from Mercury.
I know you can have a particular boat certified by HIN and power package.
Does anyone have any insight to share?
Thanks in advance!
Sydwayz is offline
Old 09-21-2007 | 07:03 PM
Chuck's Avatar
Keith at Nor-Tech service Dept. can probably get you the info you need. They are selling alot of boats overseas.
Chuck is offline
Old 09-21-2007 | 07:06 PM
rchevelle71's Avatar
I believe you need to be an Iso9000 company???
rchevelle71 is offline
Old 09-21-2007 | 09:36 PM
32storm's Avatar
CE is a euopean standard that pertains to electromagnetic radiation. Numerous electronic components are stamped with the "CE" mark that indicates compliance.
32storm is offline
Old 09-22-2007 | 02:58 AM
That is just one standard out of several CE standards.
For boats we are talking about the Recreational Craft Directive.
You can read more about it here:
http://www.mcarter.co.uk/recreationa..._directive.htm
Phazar454Mag is offline
Old 09-22-2007 | 03:23 AM
I know that many Danes who import used boats from the US use the following company to deal with the CE certification:
http://www.navalis-ce.eu/
If you can order boats from a manufacturer of the same type as the boat you are interested in with CE certification, then it is normally not a problem to get a boat CE certified by the above company even though the boat in question is not CE certified.
But I can see from the below link that there seems to be a dealer in Belgium of Active Thunder so I guess somehow CE certification has been dealt with on at least some Active Thunder models:
http://www.boatshop24.com/web/en/suc...1&totalcount=1
Old 09-22-2007 | 09:49 AM
Probably should have said that I would guess that Germans also uses: http://www.navalis-ce.eu/ since it is a German guy that runs it.
DaveSunsation
02-18-2005 08:04 PM
DaveSunsation
Sunsation
1
02-12-2005 09:13 AM
Shah Mat
05-07-2004 08:36 AM
