Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
help me does shaving weight gain mph >
Old 09-24-2007 | 04:25 PM
Default help me does shaving weight gain mph
if i shave 100lbs. will i gain mph?? how much should i expect for every 100lbs. on a 3750 lbs. boat ?? thanks for your help
scarabrun is offline
Old 09-24-2007 | 04:30 PM
Ryan Beckley's Avatar
Racer
Racer
Maybe 1 Mph........if you are lucky
Ryan Beckley is offline
Old 09-24-2007 | 04:34 PM
Tough call, on some pleasure boats maybe nothing. I'm interested to see the variety of answers on this one. How much does it speed up low on fuel. That is probably your best test every 14 or 15 gallons is a 100 lbs approx.
Jim
MOBILEMERCMAN is offline
Old 09-24-2007 | 04:59 PM
Originally Posted by Smiklos
That boat weighs more then 4300 lbs. On a straight V single a 100 lbs is around 1 MPH. Mike Carter had a boat like yours we made some simple changes it liked.
Look at the tabs see if they are dragging
engine needs more air
Hook is large
Steve
what are you talking about????????????????????????????????????????????? ?????????????????????????????????????????????????? ???????????
Old 09-24-2007 | 05:06 PM
Steve is suggesting other ways to find speed. Do you recognize the terms he used?
Jim
Old 09-24-2007 | 05:22 PM
Jim
no i dont
Old 09-24-2007 | 05:43 PM
What type of trim tabs do you have? Some brands can be installed in such a way that the drag in the water. He found with his buddies boat the engines liked more air available in engine compartment. Hook refers to the contour of the bottom. A hook helps it ride nice but reduces speed. MPH doesn't often come easy in boats, the things Steve mentioned are generally the easiest path to search. Its good info being he knows the boat.
Jim
Old 09-24-2007 | 05:59 PM
Jim
im not looking for mods info,i asked about weight,how many miles per hour can one expect from shaving 100 lbs. from a 3750 lbs, boat ,i have a 1997 scarab scs 23 ft.boat, im just wondering aboat weight ,does it effect top end ???if it does how much faster will i go if i shave 528 lbs, from the boat ,,,which would include getting rid of my friend that ways 220lbs. and 308 lbs, of fuel for a total of 528 lbs less than before, would i get 6 mph. more ??? thanks don
Old 09-24-2007 | 06:14 PM
Don- that sounds like a good excuse for a boat ride. Do the test. I'm not familiar with your exact boat to know. Some boats are more weight sensitive than others. To answer "If you can expect 6mph or more" I would say no, Maybe a couple. There are countless variables involved with weight and speed in boats. Taking weight from the bow will have a greater effect then else where. Good luck.
Jim
Old 09-24-2007 | 06:33 PM
Jim
ok i will do the test,i have only been out in the boat twice,the first time with a 23p 3 bade and then 26p4blade,with this new prop im getting 4900 rmps and 68.7 mph on a gps unit,with a 220lbs. freind and a full tank of gas 54 galons, just wondering if i shaved off 528 lbs.what to expect,you have helped me before with risers and manifold questions,thanks again don
