fluid damper >
fluid damper
fluid damper
Old 10-07-2007 | 09:31 AM
Ken N's Avatar
Arrow fluid damper
Is a fluid harmonic damper worth the money?
Is a 502 cid internally or externally balance and what size it it.
Ken N is offline
Old 10-07-2007 | 09:58 AM
hoozeyurdaddy's Avatar
if it is a stock 502, it is externally balanced and I beleive you need to run the external balanced dampener.
hoozeyurdaddy is offline
Old 10-07-2007 | 05:26 PM
Ken,
Unless something is wrong with your original damper, I dont see any real reason to change it. The Fluid damper will not do a thing for you as far as power goes. If you are building a performance engine and want to upgrade the damper, I personally would go with an ATI unit.
The 502 is externally balanced, your damper supplier should be able to tell you which one to get.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Deltarat
Drives and Lower Units
3
09-08-2008 12:28 AM
Ken N
2
09-04-2007 07:38 PM
SmallPP
1
08-07-2007 09:23 PM
formula31
20
01-08-2004 10:02 PM
THRILLSEEKER
1
06-01-2003 09:12 PM
