meltdown
Old 10-07-2007 | 11:35 PM
Default meltdown
lost #1 piston in my 496ho procharger 3.5psi is there a good forged piston and gasket that is a drop in
bob briley is offline
Old 10-08-2007 | 12:59 AM
jayhawk261's Avatar
Time to tear it down and replace everything. You can't just replace one piston without tearing the engine down and making sure everything else is ok. If the rest are ok, at a minimum you would need to re-balance the assembly for the new piston. My guess is that there will be more damage than what you see. On top of that, if one piston went, the others are not far behind. Sounds like a detonation problem which means that the stock pistons just can't handle the cylinder pressure due to age or material, or you may not have enough fuel in the system to keep up with the added demand of the supercharger. If you're going to run the supercharger, you need to build the engine to handle it and make sure the fuel system will be more than adequate.
jayhawk261 is offline
Old 10-08-2007 | 08:32 AM
Smitty's Avatar
what exactly happened to the piston?? Did it go due to detonation?? If so you need more fuel.
Smitty is offline
Old 10-08-2007 | 08:43 AM
or less timing or less boost or better cooling or fix the vacuum leak or any one of about 50 different things.
stevesxm is offline
Old 10-08-2007 | 09:59 AM
To answer your question. Yes there is. Call Tyler Crocket 810 3242720. Raylar also has pistons I believe.
bobl is offline
Old 10-08-2007 | 02:42 PM
Figure out what made this one go before you rebuild..... Unless you like rebuilding engines all the time.
kennyo is offline
Old 10-08-2007 | 04:41 PM
muffman's Avatar
I have 7 pistons with no run time if you need one. Or just sell me your procharger kit.
muffman is offline
Old 10-08-2007 | 10:07 PM
detonation,or lean out,lost head gasket too,it all went fast,did not hear a thing,just lost power.look like im going all stock and no procharger.going to get a remanufacturd 496 from merc.oh well it was fun for 60hrs
Old 10-08-2007 | 10:52 PM
muffman's Avatar
Do you want to sell your procharger?
muffman is offline
Old 10-08-2007 | 10:59 PM
thinking about it
