CMI ETOP tailpipe conections >
Old 10-12-2007 | 02:53 PM
Ran-Dom 32's Avatar
Default CMI ETOP tailpipe conections
How many flange types were made? & are the tailpipes compatible? If you have an older style Etop can the connection be fabbed up to work with the mercury style (500efi) tails??
Ran-Dom 32 is offline
Old 10-12-2007 | 03:46 PM
Ran-Dom 32's Avatar
is this an old design?? & would I be able to get new tails that terminate prior to the transom (connect to tips)
Old 10-12-2007 | 05:56 PM
Strip Poker 388's Avatar
Rob
I know of 2 flange types.rope style gasket, flat type gasket.
Strip Poker 388 is offline
Old 10-12-2007 | 07:28 PM
Your headers are the old rope seals. I always liked these better than the new flex flair seal, the Mercury header flange is flat. You can easily modify your tails to work. Or, send them to CMI, and have them do it.
Bawana
Bawana is offline
Old 10-12-2007 | 07:47 PM
Rob
I like the Stellings better , just put a bead of high temp rtv and let it rip.
The merc flat style gaskets are 20.00 each dealer cost. thats stupid insaine, Trick sells them for 7 a pc. just think of the collector gasket of a header for a car. $2-3.00
Old 10-15-2007 | 08:05 AM
Ran-Dom 32's Avatar
Bawana
any idea on the cost? to convert them
Old 10-15-2007 | 08:21 AM
fastlane40's Avatar
The tail closest to the camera.What does it suit-Bravo?Looks like mine.Why would you not use this setup,noise?
fastlane40 is offline
Old 10-15-2007 | 08:44 AM
Ran-Dom 32's Avatar
yes they are bravo set-up's through transom tails, I am concerned about noise but not so much as not wanting to hog out the transom holes to 4.5 (although it is an option)
Old 10-15-2007 | 08:49 AM
Ran-Dom 32's Avatar
another angle
Old 10-15-2007 | 10:19 AM
Elite Marine's Avatar
Send me an email to:
[email protected] or call Bill at the shop. There is an adapter.
Kirk
Ateco Engine and Dyno Shop (847)623-2737 - Your CMI Source
Elite Marine is offline
