Camming a 598' for endurance and torque >
Old 10-12-2007 | 10:14 PM
IRONMAN's Avatar
Default Camming a 598' for endurance and torque
Would a hyd roller or a solid roller get me closer to 500 to 600 hours of service life if adjusted at normal intervals? I plan on running at a max of 5500 rpms and making big torque, I am not trying to get 800hp out of this, maybe 650 to 700hp
IRONMAN is offline
Old 10-12-2007 | 11:02 PM
http://www.iskycams.com/redzone.php
http://www.iskycams.com/springs.php
Happy reading
Back4More is offline
Old 10-13-2007 | 03:56 AM
You will still need to probably replace the valve springs every 150hrs due to the high lift it will need to work well with 598ci.
Griff is offline
Old 10-14-2007 | 08:48 AM
KAAMA's Avatar
Not sure how many hours you'd get out those engine(s), but 650-700hp out of a NA 598cid shouldn't be too difficult. Lots of factors determine the endurance/longevity of and engine, but one thing that will help is a cam with a profile that is easy on the valve train and install a shaftmount roller rocker arm system vs a stud mount---and use really high quality valve springs. The valve train is a Big Block's weakest link. You can install a shelf cam if you want or for only about $70 or so more, RMBuilder/Bob Madara of Marine Kinetics will get you a cam that is tailor fitted to your engine's specs/application. Have Fun.
KAAMA is offline
Old 10-14-2007 | 03:15 PM
ROB FREEMAN's Avatar
ive got rm buider hy roller he cut for my 598 id be willing to sell dyno time only
ROB FREEMAN is offline
Old 10-14-2007 | 03:58 PM
Rob, please post cam card/specs.
800XCR is offline
Old 10-14-2007 | 06:28 PM
hers the cam card
Old 10-14-2007 | 07:12 PM
Thats a great cam grind with some big 350+ heads.
Old 10-14-2007 | 08:32 PM
IRONMAN's Avatar
Originally Posted by ROB FREEMAN
hers the cam card
Why would you want to sell? It looks like a nice grind for a 598. Did you switch to solid?
IRONMAN is offline
Old 10-14-2007 | 08:36 PM
exactly i run worked 345 drt pro ones , im going to have bob cut me a solid roller and try the new red zone lifters from isky always in search of mo power !!
