move from 30p B1 to 32p B1 >
Old 10-17-2007 | 08:02 AM
Default move from 30p B1 to 32p B1
Can I move from a stock 30p B1 to a labbed 32p B1 without losing RPM? I know the answee will depend in part on how the 32p has been labbed, but am wondering if a 2 inch increase in pitch results in an rpm decrease that is more than the 200-300 rpm that you can pick up with the labbing. Thanks for any help.
bouncedcheque is offline
Old 10-17-2007 | 11:38 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
"Standard" templated Labbing on a 32 Bravo 1 propeller will gain 300 rpm. The loss of rpm going from a 30 to a 32 is 300-400 rpm.
Many thing influence the numbers. Use the above as a rule of thumb.
[email protected]
bbladesprops is offline
Old 10-17-2007 | 12:19 PM
Stock 30 to labbed 32 should spin about 100-200rpms less. It also depends at where you are in relation to you WOT throttle rpm range.
Griff is offline
Old 10-17-2007 | 07:40 PM
Thanks - Brett already spoke with one of your staff and am sending my paperweight/prop to see if it can be repaired - two ears are bent at 90 degrees and he thinks it might be doable? I hope.
HiPerf2000
Swap Shop
3
10-12-2022 02:49 PM
Boomer35
Prop Talk
0
10-28-2008 08:00 PM
mv35
Prop Talk
3
05-03-2006 05:17 PM
