Always Something Breaking
Old 10-21-2007 | 12:42 PM
lucky strike's Avatar
Default Always Something Breaking
Took the boat out for a ride today and the tachometer starting acting up. Does anyone have one of these? It's 3 & 3/4"
LS
PS-The boat ran great
lucky strike is offline
Old 10-21-2007 | 05:35 PM
Almost every time you have malfunctioning/acting up lights or instruments, its often caused by poor contacts.
Go to radio shack buy:
DESC: DeoxIT contact cleaner is a fast-acting deoxidizing solution that cleans, preserves, lubricates, and improves conductivity on all metal connectors and contacts. Use as a general treatment for connectors, contacts, and other metal surfaces, and on non-critical metal surfaces with severe oxidation and corrosion. If the metal surface is discolored, it is severe. DeoxIT dissolves the contamination and protects the surface.
And have junior climb under the dash and clean/spray the connections. Should solve the problem.
Zudnic is offline
Old 10-21-2007 | 05:53 PM
VelocityMark's Avatar
Make sure all of your grounds are tight. A bad ground will do all sorts of things also.
VelocityMark is offline
Old 10-21-2007 | 10:13 PM
Audiofn's Avatar
Charter Member #232
If it does wind up being a bad guage then maybe some one like Lavorsi could rebuild it for you. Just toss in a temp guage for when you have it out for repair.
Jon
Put your best foot forward!
Audiofn is offline
Dock Holiday
Baja
38
07-22-2008 10:51 AM
drypipetiger
03-17-2006 10:43 AM
mikmak2004
0
06-16-2005 12:44 PM
f303sr1
05-10-2005 06:09 PM
BAJA WILL
03-16-2004 07:58 AM
