Rear Crossover on intake manifold >
Old 10-22-2007 | 08:59 PM
Default Rear Crossover on intake manifold
Anyone ever put a rear crossover tube on the back of the intake manifold to help eliminate hot spots in the cooling system (heads) and have a more even water temp. You would run a tube from one side to the other with a T in the middle and run a small discharge hose overboard.
Mike
Noise Pollution is offline
Old 10-22-2007 | 09:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I ran tubes from the rear passages up to the front passages. I'd think your's would work better. Just didn't want to add any dump ports in the hull.
US1 Fountain is offline
Old 10-22-2007 | 09:47 PM
Can't view you pic, but I get the idea. I think running a dump would help with high water pressure also. I peg the gauge at wot.
Old 10-23-2007 | 12:51 PM
Strip Poker 388's Avatar
Rob
Nice lines
Strip Poker 388 is offline
Old 10-23-2007 | 12:56 PM
I have run mine from the rear to the front 3/8 lines work well. Others I have known to just dump them over board. Dyno testing proved without mild and up built BBCs didnt last long without the mod.
turbo2256b is offline
Old 10-23-2007 | 03:51 PM
Ginger or Mary Ann?
I agree with it lowering the water pressure. I did not have a pressure problem, so it wasn't a factor on my setup. I know of 1 member who did dump the rear jackets into the exhaust tubes at the transom for a cleaner look and to control his pressure.
My current boat also pegged the WP gauge at 3500rpm. Stock 502MPI's. Easiest fix was the Merc relief valves.
Old 10-23-2007 | 05:07 PM
Scarab28's Avatar
OK - you guys confused me, would you do this mod to lower water pressure or reduce temperature hot spots in the heads? Uneven temps would be my concern.
Scarab28 is offline
Old 10-23-2007 | 07:47 PM
Do it for both. Thats my idea anyway.
Old 10-23-2007 | 08:09 PM
We have been doing that for years. I usually run # 8 Aeroquip hose from front to rear. As discussed earlier this mod works very well for equalizing chamber temps. It will never hurt you.
mrhorsepower1 is offline
Old 10-23-2007 | 11:54 PM
Rob
On my Scarab I ran a #12 from the rear to the front T ing into the front then going to the headers.
My Hustler Whipples came with a 1/4 line dumping overboard.
I guess its releaving steam/air pockets.
Scarab pick ya kinda can see the #12 T fitting on the front
Attached Thumbnails Rear Crossover on intake manifold-oil-cooler-4-02-07-010-medium-2-.jpg   Rear Crossover on intake manifold-aa-scarab-engine.jpg
