Seawater pump pulley wobbles >
Old 10-28-2007 | 01:22 AM
Default Seawater pump pulley wobbles
I just replaced my 454 merc Gen ? seawater pump (fuel pump attached) with a supposedly new unit. I noted that the pump pulley has a pronounced "wobble." The shaft seems to be straight, but the pulley is like "cocked off." I think I recall a similar wobble on my old seawater pump, but always figured that some mechanic must have dropped a hammer and bent the thing. The new unit seems much more pronouned. Is this normal? Or was I sold a bad unit. Thanks.
BigFish is offline
Old 10-28-2007 | 01:59 AM
Its probably pressed on crooked.
Griff is offline
Old 10-28-2007 | 04:43 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Previous boat was same way. I was able to clean up the pulley a bit from where it sheared itself on, then press it on just a bit further onto the unsheared bore. Just a 1/8" or so more I think, not enough to put the belt off alignment. Might be able to place a couple washers behind the mounting bracket to move the whole pump out if you have to press the pulley on to far for a straight running belt. Just a thought.
US1 Fountain is offline
Old 10-28-2007 | 09:45 PM
Big Block Billy's Avatar
Post
I've seen this several times, pulley can get distorted because it is stamped steel. I put a Gen5 motor in a boat a few years ago and ended up smacking the pulley with a hammer until it ran true. Don't hit too hard just be patient and finess it. BBB
Big Block Billy is offline
Old 10-28-2007 | 10:15 PM
Default Options: Beat it, Return it, or live with it?
I 'm trying to decied if I should return the thing, try to straighten it, or just live with the wobble; the wobble seems bad but the belt does seems to track straight on the idler and crank pulley. I really don't want to pull it off again cause it is a pain and will burn another weekend, can you straighten it by pounding it with a hammer while installed? Can that damage anything else like bending the shaft. Did the Parts guys (Lighthouse Marine Supply) sell me a bad / remanufactured part when I thought I was buying new? Or is this wobble common on new pumps?
BigFish is offline
Old 10-29-2007 | 01:46 AM
Mine had some wobble also and I never had any issues. Just not sure how much off your is without being able to see it.
Griff is offline
Old 10-29-2007 | 02:32 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Return it. Probably will wear out the bearings over time, or cause the belt to jump if running hard or hitting hard seas.
Reckless32 is offline
BillR
27
08-10-2008 11:31 PM
BigFish
1
10-29-2007 07:09 AM
BillR
4
02-06-2007 03:23 PM
turnerrd
1
08-17-2006 09:38 PM
tblrklakemo
06-21-2006 12:28 AM
