Myco Trailer - socket to fit lug >
Old 10-30-2007 | 07:56 AM
Wild's Avatar
Default Myco Trailer - socket to fit lug
My myco lugs are almost the same size as the hole in the rim, is there a special thin wall socket made for these, I have 3 deap well socket sets and none of the sockets will fit inside the hole and go over the lug.
Help
Wild
Wild is offline
Old 10-30-2007 | 08:18 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do you have a Harbor Freight Tools closeby? This is where I found sockets to fit mine. They have some thin wall sets, and an impact set that has plastic sleeves over them. If you remove the plastic sleeves, the socket slips right in the hole.
I've had the the same issue on the boat trailer, my old truck's custom wheels, and my car's custom wheels too; so I have sets that fit in each vehicle, along with breaker bars.
Sydwayz is offline
Old 10-30-2007 | 11:17 AM
Bought mine at Advance auto or some consumer oriented autoparts store.
One thing to consider: Some deep sockets only have the ID hex milled a short distance from the end. If you have a decorative cap on the end of your lug nut, it may prevent the socket from fully engaging the hex sides of the nut.
Chart is offline
Old 10-30-2007 | 03:21 PM
Tony Montana's Avatar
The BAD Guy
Dam all the money Myco gets for the trailer you would think they could give a socket that would fit
Tony Montana is offline
Old 10-30-2007 | 03:34 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I use a Craftsman deepwell socket. The impact sockets are too thick to fit in the bore.
US1 Fountain is offline
Old 10-30-2007 | 03:43 PM
Registered User
I picked up a couple of them at Summit Racing. I have the same problem with my Weld's They're impact-rated and work well. Can't remember if they're Gorilla or McGard brand. I'd look but the Ex isn't here and it's in the glovebox.
Chris Sunkin is offline
Old 10-31-2007 | 07:46 AM
I keep one in the truck , need a deep thin wall 12 point socket.
bgchuby01 is offline
Old 11-03-2007 | 08:12 AM
Wild's Avatar
how did you get that sleeve off, i got a set but the sleeve keeps it from going in.
Wild is offline
Old 11-03-2007 | 08:48 AM
bcschoe's Avatar
BRAD SCHOENWALD
Keep it simple.... Use a 13/16 plug socket...You can will always find one in the back of my truck..
BTW, did you get my voice MSG?
bcschoe is offline
Old 11-03-2007 | 01:57 PM
Wild's Avatar
yep, i will try to fax it monday or bring it with me. I am leaving monday morning with the boat and trailer
Wild is offline
