Bravo X1 drive growl >
Old 10-30-2007 | 10:43 AM
Rage's Avatar
Default Bravo X1 drive growl
Is it normal for a Bravo X1 drive to growl when the steering is at the stops/limit of turn travel while idleing in gear? When I move it a little from max turn angle the growl stops. I never noticed this noise before. The 496HO and drive now has 220 hours on it and this manuver is used when I back the boat out of its slip.
Rage is offline
Old 10-30-2007 | 01:00 PM
mine doesn't make any growl...
twanger is offline
Old 10-30-2007 | 11:03 PM
Is this a new noise?????
U-Joints are probably in need of replacement.
Griff is offline
Old 10-31-2007 | 01:22 PM
Wild Card 09's Avatar
the Flightmaster
If it is affected by steering angle, then it is something in the driveshaft area. Does it happen in both directions?
Maybe it is time to look at driveshaft bearings.
Easy enough to check.
Remove drive (six bolts) from transom assembly and slide the drive out (disconnecting the shift cable as you go).
Check the u-joints. They should move freely in all directions. Check the gimbal bearing at the same time. Even the slightest resistence indicates critical bearing trouble.
Don´t ignore the issue. It will get worse.
Wild Card 09 is offline
Old 10-31-2007 | 01:29 PM
the Flightmaster
One more idea.............
Do you have the drive trimmed up high when this happen?
If you are idling to your trailer, quite possibly.
It could be that the combination of trimmed up drive (even if only partially) together with full steering lock produces enough angle at the UJ´s causing them to bind a little. It might be no more than that, and you have nothing to repair
However, try to avoid it happening.
Old 10-31-2007 | 05:12 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Not the PS pump dead heading from being at full lock?
US1 Fountain is offline
Old 11-01-2007 | 09:39 PM
Sounds like growley gimble bearing to me. Pull the drive and go from there.
JJS2007 is offline
Old 11-02-2007 | 07:54 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
I too would thing U joints or gimble brg.. Best to play it safe & pull the drive to check em.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
1BIGJIM
Wanted
10
05-16-2008 10:12 AM
thsorens
18
07-07-2007 04:22 AM
Chris288
1
04-13-2004 11:19 AM
panteraracin
3
02-07-2002 10:36 PM
