Alpha 1 Gen II reseal >
Old 10-30-2007 | 05:59 PM
Default Alpha 1 Gen II reseal
Hi:
I have Alpha I Gen II drive 400 hrs, used 5 summer seasons. The oil seal where the drive shaft goes in to the upper gearcase is leaking and loosing pressure. there is no water in the oil.
Can this seal be changed without doing a complete rebuild, checking rolling torque and gear heights, ect..?
Should the entire drive be resealed now that one oil seal has failed?
When removing the water pump, I noticed the drive shaft can move up and down in the lower gear case quite a bit and the warer pump wear plate is slightly worn. Is a little movement correct? or will this need to be check to add more shims? Water pump is two seasons old.
Great info on the Web site!
Thank-you,
Anthony
acmpcm is offline
Old 11-01-2007 | 08:57 PM
mtgbiker's Avatar
the upper drive shaft housing seal can be replaced without having to do any rolling tourque checks or reshimming.
the drive shaft in the lower unit will move up and down until the unit starts to move then it sets its own gear lash when the upper brg cone is seated in its race. the groves in the wear plate unless they are real bad will not hurt any thing.
good luck
mtg biker
mtgbiker is offline
Old 11-04-2007 | 03:58 PM
I would reseal the whole drive if you already have it apart. Very easy to do. Dont worry about shimming just remember where everything goes and have the correct torque specs for it all. Take your time and good luck.
JJS2007 is offline
Old 11-05-2007 | 07:14 PM
Thank-you for your responce.
I have the shop manual and have read it many times.
I am tring to fiqure out which mercrusier tools are needed for the reseal job
Anthony
acmpcm is offline
scorpion king
Drives and Lower Units
5
09-06-2007 05:14 PM
Fenderjack
3
06-24-2007 10:45 PM
superiormgmtco
5
01-29-2007 05:31 PM
srracer
2
04-20-2006 03:49 PM
Raven
6
06-09-2003 06:18 PM
