Go Back  Offshoreonly.com > Owners Forum > Sonic
42ft genset installation >
Old 11-05-2007 | 12:53 PM
Default 42ft genset installation
I just ordered a new Westerbeke genset and plan to install it myself. I found the wiring harness provided from the factory close to the mounting location so those connections should be straightforward. But, I have a couple questions for anyone who's done this and/or know a bit about it:
Fuel - do you just tap off one of the tank lines at the valves under the rear seat?
Battery - do you install a seperate one for the genset or just pull power from one of the existing two?
Anyone have a fresh water flush system that does the A/C as well? - any ideas on how to do this properly?
and last... anyone have any pictures of a 42 with one installed? a picture always worth a thousand words...
Thanks all... Tony
tgracer is offline
Old 11-06-2007 | 11:18 PM
Hey Tony,
The wiring harness on on the port side might be set up for a Kohler genset, I know they were in 99 so you might want to check that first to see what adapteryou might need. As far as the battery run a separate battery for the gen, do not connect it to anything so if you kill the batteries you can start the gen and turn on the battery charger and start the engines. Finally on your fuel tank there should be a place where you can put a fitting in and tap off of that straight to the generator...Just make sure you put a vent loop and fuel water seperator in the line...Good luck
Jimi
stretchnout is offline
Old 11-07-2007 | 12:51 PM
whats going on Jimi. We never made it up there this year it was on thing after another. Give me a call I have a question and you might be able to help man.
Terry
434 531 8169
runnin gun is offline
Old 11-08-2007 | 07:14 AM
Thanks for the help Jimi. Any advice on setting up a flushing system? Or, is it really not needed?
tgracer is offline
Old 11-08-2007 | 07:03 PM
Hey tgracer,
The best way to flush the a/c is put a adapter on a small pump and push in in the discharge hole and pump it backwards through the system and open the seacock until you see the water run out...This is the way also to winterize the system....The other way is to put a T-fitting in the line just after the seacock and attatch a hose and close the seacock and turn on the a/c unit....
farfrumwerken
Sonic
9
04-14-2006 12:22 PM
amarek
Baja
1
07-20-2005 08:22 PM
97BossHammer
08-20-2004 07:08 AM
Andree
02-07-2004 05:17 AM
JOHN G
3
09-18-2002 02:27 PM
