Marine Tex on Donzi hull >
Old 11-06-2007 | 03:42 PM
Default Marine Tex on Donzi hull
Hi All
Im looking at a new used boat and on the hull toward the rear of the boat there is 2 small about the size of quater (not exatly round but about that general size) looks like gray marine tex no cracking or any thing around it just these two spots. Is that a common practice in a gelcoat repair onm the underside of a boat. Thanks for any advice.
mattd7 is offline
Old 11-06-2007 | 04:18 PM
zimm17's Avatar
Well I don't know if it's "normal" but I've marine-texed the bow edge of my hull where I got stuck on a oyster bed. It sands right on down to match the shape of the hull. Is it in anyplace to see the back side of the repair? I'd be worried about a hull puncture.
zimm17 is offline
Old 11-06-2007 | 04:40 PM
Yes i can see it its right in the blidge it has not been repair inside the is no sign of a puncture.
mattd7 is offline
Old 11-06-2007 | 05:46 PM
Wobble's Avatar
SORE MEMBER
Not normal, but marine tex is a good product for that. Is it possible that the damage you see was caused by the bunk board bolts on that or another trailer?
Wobble is offline
Old 11-07-2007 | 07:04 PM
Rage's Avatar
FYI. I recall reading some where that polyester resin like gelcot will not work if applied over the top of the epoxy resin based Marine Tex should that become an issue.
Rage is offline
Old 11-08-2007 | 10:15 AM
poly sticks to epoxy and vice a versa, poly to cured poly has molecular bonding issues. read the data on the West system website very informative, lots of good info.
excalibur32 is offline
Old 11-08-2007 | 09:40 PM
Rage's Avatar
I chatted with them on line and you are correct and I stand corrected.
Rage is offline
tjpipkens
6
07-17-2015 09:49 AM
Shanghied Again
Donzi
6
03-26-2007 10:32 AM
lightningbay
01-16-2007 05:08 PM
blue thunder
4
04-04-2004 05:22 PM
