Winterizing made easy? >
Old 11-08-2007 | 07:45 PM
Smile Winterizing made easy?
Anyone know of a remote water drain system for easy winterizing a 502 mpi that i can mount before i reinstall my motors?
Ralph
ralphspa is offline
Old 11-09-2007 | 01:07 AM
It can be easily made with brass fittings from the plumbing section at the hardware store and some rubber hose. Fitting with nipple to go in block, connect to rubber hose, connect an end cap fitting or valve on the other end.
Griff is offline
Old 11-09-2007 | 03:59 AM
Problem will be scale build up will block the lines then leave water in the block and heads and then in the spring you will have a big fat crack
flying J is offline
Old 11-09-2007 | 06:33 AM
if they are pluged just use a blow nozel with about 100 psi and blow in them they will open and drain.
rssteiny is offline
Old 11-12-2007 | 06:21 PM
thats kinda what i figured although i saw a kit on the net a few weeks ago and cant find it anymore.
Thanx Ralph
ralphspa is offline
Old 11-14-2007 | 06:51 AM
East Coast B's Avatar
As Griff stated...... just some brass fittings from the hardware store. I connected an orange colored hose to the drain fitting on the oil cooler and ran it to the front of the bilge. It's the hardest drain to get at on a twin engine setup. Now it's a breeze. The blocks and exhaust drains are pretty easy though it would be simple to do the same thing with them.
As a precaution, I always catch the water in a 5 gallon bucket to measure what comes out to assure I'm getting everything. Big Block = 5 gallons
East Coast B is offline
Old 11-15-2007 | 12:19 AM
Right on , i guess im gonna make u a few lines too
Thanx Ralph
ralphspa is offline
1BIGJIM
29
07-16-2013 10:27 AM
Hardin Marine
New Products and Member Discounts
0
06-10-2008 06:28 PM
NASCAT
09-17-2006 08:28 AM
Reed Jensen
10-14-2004 03:30 PM
Rippem
7
10-01-2003 01:35 PM
