throttle body >
throttle body
throttle body
Old 11-11-2007 | 03:35 PM
Ken N's Avatar
Arrow throttle body
Is there a throttle body upgrade for a 1999-502 MPI. If so who makes and sells it.
Ken N is offline
Old 11-12-2007 | 05:10 AM
I did send an e-mail last friday to Arizona speed for the same thing, but till now no answer yet.
Harry
D Harry is offline
Old 11-12-2007 | 03:15 PM
Ken N's Avatar
Harry
If you get a answer let me know
Ken N is offline
Old 11-13-2007 | 12:51 AM
articfriends's Avatar
There is no aftermarket throttle body that bolts on a 502 mpi that exist that I can find,the one azsm sells is for a hp500 and will not work. However I can bore yours out and install larger throttle blades,its worth approx 10 hp/ft lbs of tq on a modified motor (thats what I saw in back to back testing on the dyno) Smitty
articfriends is offline
Old 11-13-2007 | 08:28 AM
How much? I'm pulling mine out tonite to re-ring and freshen up for next year.
kennyo is offline
Old 11-13-2007 | 05:13 PM
Ken N's Avatar
articfriends
How much will it cost for the boreing and blade work.
Ken N is offline
Old 11-14-2007 | 02:25 AM
You both have mail. I'm going to be gone from this saturday until sunday the following week so if you don't hear back from me I'll get back with you asap,Smitty
Old 11-14-2007 | 02:44 AM
Ken,the bored out throttle body is worth more than 10 hp on your blower motor too,unfortunately after we made 1115hp on the dyno we got so excited we never bolted the stock throttle body on to see how much power we would lose,Smitty
Old 11-16-2007 | 10:17 PM
Smile
Hey Smitty it's good to see you got that T/B upgrade going. I did this last spring and am finally getting around to putting it all together.
Did you run into any problems getting the EFI to work right with more air at given throttle settings?
I am looking for a base map to start with, worried about being lean.
Looks like you got that thing close to the century mark
midwest272 is offline
Old 11-17-2007 | 12:45 AM
The tune didn't really change on the dyno going back and forth from the stock to the modified throttle body,the biggest thing is ensuring your tps base setting is the same as before and correct and that your iac counts aren't too high. I had to drill a 3/16 inch hole in each of my throttle plates to get my iac counts/idle correct but it wasn't because of the larger throttle plates,it was the bigger cam with less idle signal,Smitty
BaReNBoO42
22
12-16-2020 10:48 AM
CIG3
0
04-25-2006 03:43 PM
Rage
4
02-12-2006 12:24 PM
Rage
1
01-24-2006 01:13 AM
BAD-HABIT
4
08-07-2003 11:55 AM
