Hepp Please,Floor jack was pump up??? >
Old 11-20-2007 | 12:16 AM
Strip Poker 388's Avatar
Rob
Arrow Help Please,Floor jack want pump up???
I got the boat trailer jacked up on stands and I cant get it down,
Its a Walker/Linclon jack made for napa # 91-652 height 3 3/4 to 24...2 ton
With the jack down ya start pumping it ,it pumps a little but it leaks right back down,
The vent looking cap on the top I took off it looked low of oil and added some to it,I think it was low,now it want even mover up any,I guess thats were ya put oil in it??
I tried with handle valve closed pulling up on jack to the top ,open valve then let down,this doesn't seem to bleed it..
It also would leak down real slow when jacking up a viechle.
Is there any of you thats knowledgeable on these jacks etc
Thanks for any help in this matter,Im stuck
Rob
Strip Poker 388 is offline
Old 11-20-2007 | 12:18 AM
masher44's Avatar
try less beer
masher44 is offline
Old 11-20-2007 | 12:20 AM
PhantomChaos's Avatar
Its a Walker jack made for napa # 91-652 height 3 3/4 to 24.2 ton
With the jack down ya start pumping it ,it pumps a little but it leaks right back,
The vent looking cap on the top i took off it looked low of oil and added some to it think it was low,now it want even mover up ant,I guess thats were ya put oil in it??
I tried with handle valve closed pulling up on jack to the top ,open valve then let down,this doesn't seento bleed it..
Is there any of you thats knodgalble on these jacks etc
Thanks for anyhelp in this matter,Im stuck
Rob
Rob......like Masher said! Less beer!
PhantomChaos is offline
Old 11-20-2007 | 12:38 AM
My last jack did the same thing. It was 15 years old. Tried the same things as you and nothing worked. Figured it was just easier to put it in the dumpster and get a new as opposed to trying to get the hydrauilcs fixed. Bought a new one on sale at Sears.
Griff is offline
Old 11-20-2007 | 07:27 AM
Audiofn's Avatar
Charter Member #232
The seat is probably worn out. People ALWAYS over tighten the things and ruin them. When they are new all you need to so is just barely seat the things and they work. For some reason people feel the need to really tighten them. This puts a groove in the seat and it will no longer work. Back out the screw that the handle goes into and I am betting there will be a ridge on it.
Put your best foot forward!
Audiofn is offline
Old 11-20-2007 | 08:24 AM
Outdrive1's Avatar
Masher touches my
Rob
You're probably gonna need a new jack, I've never been able to fix my old ones that leak.
What were you doing anyways? Looking for porn under the boat?
Outdrive1 is offline
Old 11-20-2007 | 08:32 AM
Smitty's Avatar
Sounds like you need a higher capacity jack. My 3 ton roller jack would not lift my steel trailer with the boat on it. I bought a 20 ton bottle jack and it lifted the whole side into the air with ease.
Smitty is offline
Old 11-20-2007 | 08:56 AM
Outdrive1's Avatar
Masher touches my
BTW, you must have been on the beer when your wrote this........
"Hepp Please,Floor jack was pump up???"
Old 11-20-2007 | 09:08 AM
OldSchool's Avatar
BEER, it's what's for dinner!!!!:ernaehrun g004:
OldSchool is offline
Old 11-20-2007 | 09:12 AM
Audiofn's Avatar
Charter Member #232
Remember there is no beer value in food but there is food value in beer!!!
Audiofn is offline
