525 EFI question?
Old 11-23-2007 | 06:54 PM
Full Throttle 525's Avatar
Default 525 EFI question?
Okay:
I have a single 525 EFI with about 300 hours on the engine and drive. Everything seems to run fine, with the exception of some minor part failures. At what point should I start thinking about doing something before something happens? And what should that something be?
Thanks in advance for the response(s).
Ron
Full Throttle 525 is offline
Old 11-23-2007 | 07:47 PM
Elite Marine's Avatar
Hey Ron -
I'm sure some more experienced Merc guys will chime in, but I would recommend at least a top end rebuild by now, springs and the valve train are really the only thing that should need to be addressed.
A leak down and compression check should give you an indication of the health of the engine.
Better to do the heads now than loose a spring or retianer and drop a valve. Cheap insurance.
Have a great weekend,
Kirk
Elite Marine is offline
Old 11-23-2007 | 08:43 PM
GO4BROKE's Avatar
Originally Posted by Pantera28-650HP
Hey Ron -
Kirk
Sounds like good advice to me.
[img][/img]
GO4BROKE is offline
Old 11-24-2007 | 03:48 AM
Agreed also. Spend 2 grand soon to avoid a major failure later. Valve job, springs and lifters.
Griff is offline
Old 11-24-2007 | 07:56 AM
JIMKID Motorsports's Avatar
kirk hit the nail on the head ha ha no seriosly thats what i would do
JIMKID Motorsports is offline
Old 11-24-2007 | 12:51 PM
Couln't agree more!
Ray @ Raylar
Raylar is offline
Old 11-24-2007 | 02:17 PM
Pwrbt33's Avatar
YUP, good advice!
Pwrbt33 is offline
Old 11-24-2007 | 02:50 PM
lucky strike's Avatar
Leak down & new headers.
LS
lucky strike is offline
Old 11-24-2007 | 03:58 PM
Thanks Guys...appreciate all your help. I'll get right on it.
Ron
Old 12-25-2007 | 02:20 PM
Okay: I had a faulty crank shaft sensor and had a throttle response adjusted. Now I can't seem to get the RPM's to 5250with my 24 B1 prop where I used to almost hit the rev limiter with it before. Any quick thoughts?
Ron
