Switching from efi to carbs, which intakes should I use? >
Old 12-01-2007 | 09:00 AM
ls1nova's Avatar
Default Switching from efi to carbs, which intakes should I use?
Well guys, I'm leaving my area of knowledge, and switching from efi to carbs. Which intake would best suit my needs? Here's the engine spec's 502, AFR 315's, 8.75-1 compression, crane 741 cam.
I really need something with brass inserts in the water passages, unless I go with closed cooling. But I'm not sure I'm going to bother with the closed cooling, I would rather just get an intake with brass. I will also need a 4150 base, going off of what the carb shop is reccomending.
I guess I better explain that I'm not switching to carbs because the efi is a pain in the azz or anything, It's simply a money issue. I'm building a twin to the motor in my Velocity and putting them both in the Powerplay. So buying 2 harnesses/computers, 1 more intake/throttle body/injectors, ect. it will be way more affordable to just switch both to carbs.
Thanks,
Frank
ls1nova is offline
Old 12-01-2007 | 09:22 AM
Might get some better response in the General Tech area. Should be an easy questions for one of the engine pro's.
Good luck!
29scarab is offline
Old 12-01-2007 | 09:24 AM
ls1nova's Avatar
Oops! I thought I posted it there. LOL I'm loosing it I guess.
Could one of the moderators delete this thread please? I reposed in the tech section.
Thanks,
Frank
ls1nova is offline
Old 12-01-2007 | 09:37 AM
I would recommend the world products marine intakes,only one with brass inserts really work nice,I am wd with world and can get you a good deal.The world intakes combined with a holley hp950 carb works great,plenty of power,idle great and easy to work on.give me a call 410-956-5381 dave.
MDGperformance is offline
Old 12-01-2007 | 10:53 AM
'05 Concept SF23
Are they tall decks? If so I have a pair of intakes for Dominators.
f311fr1 is offline
Old 12-01-2007 | 05:44 PM
ls1nova's Avatar
They are standard deck. Thanks anyway.
Frank
ls1nova is offline
Old 12-02-2007 | 11:52 AM
CPPerformance has dart intakes and carb fo around $700.
cobra marty is offline
Old 12-02-2007 | 01:15 PM
MM1
Merlin intakes would be the best for your situation. The kit from CP does not have brass inserts in the water jacket. Buy them online at summit racing.com part # wrl-063042
MM1 is offline
Old 12-02-2007 | 02:11 PM
MrCIG's Avatar
Charter Member#330
I've got Brodix and they perform great.
Mark
MrCIG is offline
Old 12-02-2007 | 05:02 PM
AIR TIME's Avatar
I have been running the dart intake for 12yrs on a 509 at 600hp plus. I run salt water only flush out after use thats all. one dart intake I had is in my buddys boat thats 12yrs and THE ONE i have now is 7yrs went with aftermarket heads so needed new intake
AIR TIME is offline
