Fast Glass risers-problems, info? >
Old 12-01-2007 | 08:13 PM
Default Fast Glass risers-problems, info?
I bought a boat with a 454 magnum (89) and it has fast glass stainless risers on it. As i'm replacing the old, and possibly rusted out cast iron manifolds with aluminum GLM ones, a friend of mine told me to get rid of the risers. He claims they warp, especially after removing them and putting them on a new manifold, and leak water back into the engine. Has anyone else had or heard of this problem?
WHIPLASH is offline
Old 12-01-2007 | 09:21 PM
'05 Concept SF23
I had a friend run a set for about 10 years. Check the flange with a straight edge and feeler gauge.
f311fr1 is offline
Old 12-02-2007 | 10:34 AM
I've been running my FastGlass stainless risers since the late 80's on my SBC. I modified them last year into long risers from the standard short ones. I've had no problems with mine. I don't see how just removing them and putting them on a new manifold could warp them? Unless they saw extreme heat I don't think it's possible. As mentioned check the flange for straightness and make sure good gaskets are used in the riser manifold connection. I like to run the blockoff plates and route the water thru the manifold to hose to riser.
Ryan00TJ is offline
Spiker
Black Thunder
37
09-16-2007 07:48 PM
35 White Lightning
3
05-14-2007 01:09 PM
Wild
Cigarette
23
05-03-2005 10:13 AM
traviss
6
09-23-2002 03:34 PM
Audiofn
05-29-2002 09:28 PM
