rigging a steering system ??? >
Old 12-03-2007 | 01:19 AM
Default rigging a steering system ???
If I have to buy a complete steering system from helm to steering ram tiller on the bravo 1 drive, which system should I buy? I don't have the budget for external hydraulic steering right now. The boat will be a mid 60mph boat with about 400hp.
Also any helpful tips about how to install this system, or things to watch out for while installing a steering system will be helpful, this is my first time. Thanks -- TM
Trojan-man is offline
Old 12-03-2007 | 08:08 AM
offthefront's Avatar
there is a way to rig from the Helm back to the transom (internal).... You have to have the older style inner steering ram with the lines external to the ram ... then you could ad external at a later time ....I have the internal Ram if your interested ...PM me ....
Older style Ram ....
offthefront is offline
Old 12-03-2007 | 09:08 AM
You could try to get a price on the internal Zeiger hydraulic system too, if you can find someone to give you a quote.
VetteLT193 is offline
Old 12-03-2007 | 10:09 AM
northernoffshore's Avatar
isn't there a reasonable priced hynautic system in oso ads.
northernoffshore is offline
Old 12-03-2007 | 10:45 AM
can I mount the ram to the inner transom plate mount used on bravos ???
Guys thanks for your responses, I appreciate the info
Old 12-03-2007 | 10:47 AM
What type of helm should I get? I don't have room for a rack system, so do I get rotary, or hydraulic, or what ??
thnks, -- TM
Old 12-04-2007 | 05:13 PM
bouyhunter's Avatar
What is a hynautic system? I've seen the name before, just don't know what it means. Seems to be a system on older boats, no?
bouyhunter is offline
Old 12-04-2007 | 07:10 PM
Registered User
Hynautic was a non-powered hydraulic pump and reservoir- usually uses with external rams. it had the benefits of hydraulic but no power assist. Not terrible steering with two hands but you couldn't throttle and steer at the same time. Easy conversion to full-power. Just a helm swap and switch the tank from pressurized to vented. Of course you need to plumb in a pump.
if you love your boat, buy a Latham. If you really like it, buy Marine Machine. If you're ambvalent, Mayfair is your best bet.
Chris Sunkin is offline
Old 12-09-2007 | 09:27 PM
Lofty's Avatar
Full hydraulic systems are coming down in price. Just wait until 08' and you'll see the price drop. It's because of a new positive displacement pump that will be available in early Feb.
Attached Thumbnails rigging a steering system ???-3400-100-ssm-vi-power-steering-schematic.jpg
Lofty is offline
Old 12-18-2007 | 04:55 PM
bouyhunter's Avatar
Missed your reply for a few weeks there Chris - sorry - but thanks for the explanation.
My boat already has Latham, I was just wondering the difference. I've ran into the term a few times and never knew what it meant.
