Damaged Eliminator Question >
Old 12-03-2007 | 08:04 PM
Default Damaged Eliminator Question
1990 Eliminator took a shot to the right front Sponson at the running light. I hot a rock embankment on the way to getting it detailed. The boat has a whole approx. 10-12inchesx5inches around thru the deck and side(right at the rubrail)
The boat jumped after hitting the embankment and jumped smashing the floor just behind the winch. From the boat jumping it also cracked the inner gimble which holds the steering assembly on the inside gimble which is made of cast. I'm looking to see if this type of damage is repairable or based on the impact and structure consider it done?
I have photos and would like to some info if possible from anyone familiar with this type of damage. The hull is original Gel with 4 Gel stripes which surround the boat. The gel is on top of wood(Bulsa?) A big problem is access to the damage. Labor to remove the birth/interior/labor to replace the wood/Gel/Stripes?
[email protected]
Thanks Very Much
Griffin00 is offline
Old 12-03-2007 | 08:05 PM
DirtyMoney's Avatar
What area are you in?
DirtyMoney is offline
Old 12-03-2007 | 08:24 PM
OkieTunnel's Avatar
Pictures please. Doesn't sound that bad.
OkieTunnel is offline
Old 12-03-2007 | 09:04 PM
I guess it would be up to the insurance company as to whether or not its fixable or should be salvaged.
Griff is offline
Old 12-03-2007 | 09:11 PM
Send it back to LEACH at eliminator in mira loma,been down there when they put 3 foot of sponson back on the race boat and sent it back out the door
lake speed
Eliminator
8
06-29-2008 11:13 PM
CB-BLR
Prop Talk
0
07-02-2007 11:36 PM
idareya
11-14-2004 12:53 PM
FlyFast
1
08-06-2004 10:22 AM
MAX VELOCITY
4
09-11-2003 11:02 PM
