Prop Reccomendations Please... 90 Scarab 454 Mags >
Old 12-05-2007 | 10:52 AM
Default Prop Reccomendations Please... 90 Scarab 454 Mags
Hello.
I am running 3 blade 25's and not happy w/ acceleration. Some are recomending 3 and other 4 blade.
Now when I accelerate, The tachs on the 454 mags are only @ 4,000 rpms full open and cruising which I know is hard on the engines... What should I run for a lil better performance???
Also... where is the best place to buy props... and should I go used??
Thank you so much for your advise!
new boater
shotjock is offline
Old 12-05-2007 | 11:08 AM
BY U BOY's Avatar
need more info
what size boat,drive ratio,what prop?
4000 rpm's is to low for that motor. you should be in the 4600 to 4800 rpm range.
try a mirage + 23p.
also post this in the prop section you will get more help. Call brett at bblades or julie at throttle up both are members on the board. Good luck.
BY U BOY is offline
Old 12-05-2007 | 05:07 PM
A23 mirage should bring you up 400RPM,merc says 42 to 4600rpm is were you should be with a 7.4 454 motor.
and I do have a set of 23 mirages that have acouple of hours of use on them.
PM if your intrested
boatnt is offline
Old 12-05-2007 | 07:40 PM
My 31' Excel with 454 Mags runs 5000 RPM with 23P mirage 3 blade.
Screamin' Seamen' is offline
Old 12-05-2007 | 09:53 PM
KAAMA's Avatar
Originally Posted by shotjock
Hello.
Try looking in the Prop section of this forum---you will get more prop help there.
BTW, 4000rpm is way too low for WOT. Either you have the wrong sized props or your engines are real tired and in need of a rebuild.
KAAMA is offline
Old 12-06-2007 | 05:33 AM
offthefront's Avatar
I have a set of Mirage Plus 23P ... 400.00 ... balanced and new hubs .......m
[email protected]
offthefront is offline
Old 12-06-2007 | 11:10 AM
Yes, Sorry,
It Is A 31xcel. With Bravo 1 Drives, And When Trim Is All The Way Down And On Plane, Only Getting About 4000 Rpm At Full Throttle. The Motors Have New Top Ends 40 Hrs Ago.
shotjock is offline
Old 12-06-2007 | 11:16 AM
OH, AND YES, I GUESS I WILL BE SHOPPING FOR SOME 23 P'S LOOKING AT THE RECOMENDATIONS SO PLEASE LET ME KNOW HOW MUCH YOU WOULD CHARGE FOR THEM.
THANKS!
FRANK
[email protected]
shotjock is offline
Old 12-07-2007 | 05:26 PM
FASTTIMES's Avatar
THANKS!
FRANK
[email protected]
I have the same boat, 1992 31 Excel 454 mags. I have 23p 3 blades but I'm trying to find some 22p 4 blades to try..
FASTTIMES is offline
Old 12-13-2007 | 12:11 PM
So... Should I then be looking for the 22 4 blade and just skip the 23's all together???
Any advise is greatly appreciated!
shotjock is offline
