Gen 6 502
Old 12-10-2007 | 09:09 AM
Default Gen 6 502
Will a double roller timing chain fit under the stock cover?
baja27 is offline
Old 12-10-2007 | 09:32 AM
t500hps's Avatar
21 and 42 footers
My builder used a double chain Rollmaster in my 500EFI's and it would just tap the raised sections under the cover...we ground them down and 6 motors have been running fine like that for 1-2 years.
t500hps is offline
Old 12-10-2007 | 10:42 AM
Yes, with a little modification. Like t500 said, you have to grind the raised ribs down to the level of the rest of the cover. Eddie
Young Performance is offline
Old 12-10-2007 | 11:08 AM
Grind down the inside or just the upper portion
baja27 is offline
Old 12-10-2007 | 11:46 AM
Just the upper portion where the cam gear is. You may have to test fit and grind a few times to get it all.
Old 12-10-2007 | 12:07 PM
baja27 is offline
RickR
22
02-07-2010 01:04 PM
smdude
Wanted
1
07-17-2008 08:35 AM
smdude
5
12-12-2007 04:02 PM
baja27
09-10-2007 03:20 PM
Monty
4
08-20-2003 06:55 PM
