Who has had Jim Valakeo do your heads
I have 2 pair of heads that were done by Valako I haven't put them on my boat as it is for sale I am thinking about selling them, they are cast iron casting# 049 oval port that have had him put the big valves (2.19 and 1.88)in, pocket ported and have the springs installed for a bigger cam, they have the teflon seals in also. The heads are fresh never ran yet, they should work well on any mild big block....Fred
Fred;
What kind of boat were you going to put the heads in and what were you looking for HP. I have a Big Block that is already .030 over and I would like to have the heads redone to maybe get a little more HP out of them without getting too WILD. Thanks
I bought a motor about 3 yrs ago with a set of Jims heads. They have they wedges in them along with the intake, they are merlins. These are the best heads I've seen, unreal power from a normally aspirated engine. Best of all three years and no bravo failures.
I had Jim do some peanut port heads for my 330 about 7 years ago. New intake, bigger carb, port, polish, added about 5 mph. BUT, I will never touch another peanut port head. The WILL crack between the valves (even with hardened seats). I have two sets to prove it. Makes good weight for the back of the truck in the winter!!
I had Valako do a set of heads for me, World Products rect port. Jim did a full port with wedges, fully assembled with matched intake, and I am completely satisfied with the work.
It ran on the dyno and gave me 710hp @ 6200. Jim built my whole motor (540 cu) and I run the hell out of it and it has never given me any trouble.
You do however need to have the lifters rebuilt every 150-200 hours, and you also need to keep the valves adjusted when using a solid cam. I always change my oil every 30 to 40 hours, and make sure you have a big enough oil cooler.
Check out all the guys from Michigan that went to LOTO and did well using Valako's heads.
