Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
to drain or not to drain? >
Old 12-19-2007 | 09:44 AM
copiercat's Avatar
Default to drain or not to drain?
recently i had my 33 ocean express in the shop to pull the motors to service an oil leak and they kind of put me to back burner and left my boat outside in the rain for an extended period of time without putting the cockpit cover on and left the trailer jack as low as it could go in the down position, the cabin area was filled with water about 4 inches when i looked at it, this filled up space in a closed compartment near the steps at the rear of the cabin and caused a soft spot in the floor. i cut out the wet area and discovered there is no drain to the compartment as well as the one in front of it.. my question is should i drill a drain to under the cockpit liner or would that be creating another problem? i do plan on installing access covers in the new floor.
copiercat is offline
Old 12-19-2007 | 06:32 PM
Audiofn's Avatar
Charter Member #232
I think I would go with the access covers.
Put your best foot forward!
Audiofn is offline
Old 12-20-2007 | 06:15 AM
I agree with Audio. What surprises me is you don't seem pissed?
David Stotz is offline
Old 12-20-2007 | 07:52 AM
copiercat's Avatar
im very pissed as there was a whole lot more to this story
all i can say is DO NOT USE H2O MARINE in Sarasota for work, they are the only merc high perf warranty in the area
Old 12-20-2007 | 08:42 AM
Audiofn's Avatar
Charter Member #232
That sucks man
Audiofn is offline
Old 12-21-2007 | 06:13 AM
offthefront's Avatar
Some boats the the forward bilge area seperate from the Stern Bilge area so you dont get oil/gas nasty tuff draining forward .... Sounds liike a good small claims court candiate ..take lots of pics and document everything .....m
offthefront is offline
rangerrick63
03-02-2022 07:36 PM
scarrab30
2
11-07-2007 12:13 PM
fountainguy214
Fountain
1
05-31-2007 10:39 PM
Dock Holiday
09-10-2002 12:25 PM
bearpaw
7
08-04-2002 04:21 AM
