Filling in a hole?
I used to have two water picup's on the bottom of my hull. The rocket scientist put them just in front of the drives. I think it must have been JC
The things were splitting the water and causing HUGE slip numbers. I am going to remove them and put transom mounts on it. What I need to know is the best way to fill them in. These are about 8-10 inches from the center of the V. They are about 1 1/2 inches in diameter. The glass is about 3/4 of an inch thick no core.
What material, what resin, how much do I taper in, taper on the inside and out???????
Jon
The things were splitting the water and causing HUGE slip numbers. I am going to remove them and put transom mounts on it. What I need to know is the best way to fill them in. These are about 8-10 inches from the center of the V. They are about 1 1/2 inches in diameter. The glass is about 3/4 of an inch thick no core. What material, what resin, how much do I taper in, taper on the inside and out???????
Jon
Put your best foot forward!
you still workin on that thing?
I'll be there next week an walk ya through it
08 OPA High Points Champion
so where are the "clubs" around there. last time i remember we had to drive about 30-40 minutes from Ashland
oh by the way we are going to Knights Hill in Bridgton from friday Dec. 28th to Dec. 31st up by Kurt. wanna head north?
OUCH OUCH OUCH Stop twisting my arm!!! I can probably make it up there. My house is only 15 min away!!
The Caberet is in Danvers that is about 20 or so min away from you or south to RI. I thouight that the Banana was going to be open again but have heard they got delayed. I want to check that place out as it should be all brandy new
cool . . . . i'll buz ya when i get in the area
Dave when you get done come on down to Florida and walk me thru it .........
Got the same thing in my 311 cept it's where the pump out for the head was ... I took it all out cept there is a 1.25" thru hull sticking up right in front of the Starboard motor ...That Som-***** is always pokin you in the back or ASS everytime you are working on that motor ....Its gota Go !!!!!!! ....m
I've got a similar problem in the hull of my Stinger. The transducer for the depth sounder was installed thru the hull near the front of the bilge. That's bad all by itself. To make matters worse, when I originally got the boat the transducer was mounted at 90 degrees to the bottom-which made the trim ring hang down about 1-3/4 inches on the "high" side of the hull and barely touch on the low side! Talk about drag! I filed the hole enough to get the thing to mount flush to the bottom for a temp fix but am planning on filling the hole and moving the transducer to the transom while everything is out for the transom rebuild.
