Crane HI-6M  on HP500EFI >
Old 12-24-2007 | 10:01 AM
Question Crane HI-6M on HP500EFI
I am thinking of changing over to a Crane HI-6M ignition on my slightly modified HP500EFI to help idle and cleaner plugs. All I have read is that these type of ignitions systems (MSD, Crane) are used on non EFI engines. Can these systems be used on computer controlled engines and are they a easy hook up. But I quess most importantly are they worth the extra money.
Hy-Velocity is offline
Old 12-24-2007 | 11:31 AM
CcanDo's Avatar
Crane may be working on a new system that could replace your present EFI. However, you mention slightly modified, perhaps the solution is re-tuning, relative to the modifications.
Raylar might have expertise for tuning your present system.
CcanDo is offline
Old 12-24-2007 | 12:59 PM
Thanks CcanDo for the update on Crane, the engine has alu. heads and the Crane 41 cam. The ECU was reprogramed. It seems to run OK, but would like a little more power and thought that updating the ignition system was a good next move.
Old 12-24-2007 | 04:26 PM
Doubtful that an ignition box would gain you any power. Was the ECM programmed on a dyno or with a wideband O2 sensor????? If not, that is your solution.
Griff is offline
Old 12-25-2007 | 09:10 AM
Canada Jeff's Avatar
If your plugs are dirty, or fouling, your computer isn't calibrated perfect. Are your plugs fouling??
Canada Jeff is offline
Hydrolift
0
05-21-2006 09:09 AM
dhlaw
1
03-17-2006 07:48 AM
Bob280Silencer
8
07-09-2003 11:55 AM
Sydwayz
3
05-12-2003 10:00 AM
39 Unlimited
2
07-16-2002 12:22 AM
