280 K-planes is it normal >
Old 12-28-2007 | 02:38 AM
Velocity Vector's Avatar
Crazy Energy
Default 280 K-planes is it normal
When I use the finger switch on the throttle to position my k-planes the port side goes about 1/2 way down before the starboard side kicks in and starts going down. Is this the norm? I would think they would travel together. And I was also wondering about the 380 k-planes on my 32' Velocity would they do a better job than the 280's or are the 280's what I should stay with, that's what came on it. 496 ho's . I don't know anything about a boat but I got one.
Velocity Vector is offline
Old 12-28-2007 | 03:54 AM
They should travel at very close to the same speed. One should not start moving after the other. Are you sure its not just the indicator cable sticking???
Griff is offline
Old 12-28-2007 | 08:53 AM
Crazy Energy
Cabels are not stinking, it does seem one pump is faster than the other, seems as fast as a trim pump and not a plane pump wonder if someone put a trim pump on the tab instead of a plane pump or is there even any difference in the pumps?
Old 12-28-2007 | 10:32 AM
Is it a single switch or two toggles? When you say kicks in do you mean the motor starts making noise or the plane starts to move?
MOBILEMERCMAN is offline
Old 12-28-2007 | 11:31 AM
UNSANE's Avatar
On my boat, one does travel a little faster than the other one, but they do both start moving at the same time.
UNSANE is offline
Old 12-28-2007 | 11:46 AM
Crazy Energy
single switch on the throttle along with a trim switch on the throttle, them I have 4 rocker switches for the trim and the tabs,
Old 12-28-2007 | 12:05 PM
JasonSmith's Avatar
They should move very close to the same speed. Check the connections at the pump. Check the fluid levels.
I would, judging by the comments you made about not knowing much about boats. I would take it to a shop & have it looked at.
JasonSmith is offline
Old 12-28-2007 | 01:11 PM
Crazy Energy
Yes I'm dumber than a box of rocks when it comes to boats, I did just have it serviced, a silinoid was out and they took them off and cleaned them, fresh fluid. Is there a difference in trim pumps and tab pumps as far as the speed they operate?
Old 12-28-2007 | 03:02 PM
JasonSmith's Avatar
I don't know? If there is, I want faster ones all the way around.
I'm dumb too, don't feel bad.
Old 12-28-2007 | 03:18 PM
Jason made a good suggestion too.
But back to the switches, do the pumps work consistently and evenly when you use the separate switches? Or is it only a problem with the override/ single switch?
