280 K-planes is it normal
When I use the finger switch on the throttle to position my k-planes the port side goes about 1/2 way down before the starboard side kicks in and starts going down. Is this the norm? I would think they would travel together. And I was also wondering about the 380 k-planes on my 32' Velocity would they do a better job than the 280's or are the 280's what I should stay with, that's what came on it. 496 ho's . I don't know anything about a boat but I got one.
They should travel at very close to the same speed. One should not start moving after the other. Are you sure its not just the indicator cable sticking???
Originally Posted by Griff
(Post 2385223)
Is it a single switch or two toggles? When you say kicks in do you mean the motor starts making noise or the plane starts to move?
On my boat, one does travel a little faster than the other one, but they do both start moving at the same time.
Originally Posted by MOBILEMERCMAN
(Post 2385485)
They should move very close to the same speed. Check the connections at the pump. Check the fluid levels.
I would, judging by the comments you made about not knowing much about boats. I would take it to a shop & have it looked at. |
Originally Posted by JasonSmith
(Post 2385597)
I don't know? If there is, I want faster ones all the way around.
I'm dumb too, don't feel bad. |
Jason made a good suggestion too.
But back to the switches, do the pumps work consistently and evenly when you use the separate switches? Or is it only a problem with the override/ single switch? |
| All times are GMT -5. The time now is 05:40 AM. |
