MarkIV heads to a Gen5 454? >
Old 01-01-2008 | 07:41 PM
Default MarkIV heads to a Gen5 454?
I was reading SA Design Chevy Rat Motor book and it states that MarkIV heads will not work on a Gen5 Block. Is this true?
I'llburn14u2 is offline
Old 01-01-2008 | 07:52 PM
ROB FREEMAN's Avatar
true , they will leak , differant water passages
ROB FREEMAN is offline
Old 01-01-2008 | 07:55 PM
That SUCKS the other site said they would!!! well 2008 is out 4 me already.
Old 01-01-2008 | 09:21 PM
Mr Gadgets's Avatar
Charter Member #601
I'll burn.. There used to be a head gasket that would work. I think it was a Felpro, might give them a call and see what they say.
I bought one of the first 502 short blocks released from GM before they were available to the public. Ordered it on a day when some one with some clout ordered theirs.. and mine was released. Any way, I ended up putting a set of Dart 320 heads on my gen V block and didnt need any special head gaskets. Never had a problem with leaks. The water passages in the block are tear drop shaped. The GM heads will leak unless used the special head gaskets at that time.
Hope that helps.. good luck!
Dick
Mr Gadgets is offline
Old 01-01-2008 | 10:08 PM
Rookie's Avatar
I think it is Fel-Pro 17046, thats what I use on my GenV block to MK IV heads. I have 088 and 188 heads
Rookie is offline
Old 01-02-2008 | 08:49 AM
I have the 049s to put on mine
Old 01-02-2008 | 08:50 AM
Dick
Thank You Sir I'm calling now!!
Old 01-02-2008 | 09:27 AM
woooohooooo. They will work!!!!!!!!! FelPro does make a gasket for this!!!!!!!!
Old 01-02-2008 | 08:10 PM
I have Mark IV 820's on my Gen V. They work fine. Use the Gen V gaskets. I have heard that Gen V heads have problems on Mark IV blocks.
Good luck!!!
jeffswav is offline
Old 01-02-2008 | 08:53 PM
Rookie's Avatar
what gasket and part # did you find out works??
Rookie is offline
