C M I 's
Old 01-02-2008 | 07:45 PM
Montauk Crossbow's Avatar
Default C M I 's
What is the average lifespan of CMI headers from the mercury racing factory, installed on their 500 & 525 efi's ? Have any of you guys had them start leaking internally on you ? If so ,how many hours did you run them before they leaked ,and did their failure cost you more than a replacement set .......................(ie, valves,heads ,ect. ).I've heard a few different stories ,would like to hear yours
Montauk Crossbow is offline
Old 01-02-2008 | 11:24 PM
Plenty of failures discussed with 525efi headers. The 500efi's have different headers.
Griff is offline
Old 01-03-2008 | 07:31 AM
Are they just as bad ? or do they have a better track record ,I'm looking at a boat with 500 efi's and 287 hours ,was wondering how much longer I can expect to get out of them ,and will I know when to change them before anything else gets damaged from them leaking ??????????????????????
Old 01-03-2008 | 09:21 AM
Semper Fi's Avatar
TRICK has an extended warranty plan if you buy from them
Just Kidding.......don't take this advice
Semper Fi is offline
Old 01-03-2008 | 11:28 AM
500EFI headers have not had the failure rate of the 525EFI. They are pretty much a standard CMI E Top. The 525 headers were spec'd out by Merc and they had Cmi build them.
Griff is offline
Old 01-03-2008 | 02:20 PM
ApachePete's Avatar
Mine in a 382 with 500EFI's lasted for about 200 hours. Then needed complete engine rebuilds due to leaks into the heads. And that was even with regular fresh-water flushing.
Oh: needed new headers and tail-pipes, too.
The original Silent-Choice lasted even fewer hours.
Salt kills!
ApachePete is offline
Old 01-03-2008 | 06:32 PM
Wow that sucks, Did you keep the boat in year round ? any signs of leakage prior to head job ????????????????????
Old 01-03-2008 | 08:26 PM
my cig has 300 hrs no problems with the headers yet on my 500 efis hope i didnt just jinks myself
tony stamis is offline
Old 01-03-2008 | 08:33 PM
stecz20's Avatar
stellings i had zero problems with mine..
stecz20 is offline
Old 01-04-2008 | 09:40 AM
Elite Marine's Avatar
As Griff stated, the 500 uses the Elbow Top Header which is a very durable long lasting header. The 525 used a Merc specified and designed header that appears to have higher failure rate than other designs.
Providing the headers were drained and/or flushed if used in salt water, properly winterized in cold climates and had adequate water flow while running, they will last as long as any other exhaust system.
You can pressure test them and if there is an issue, they can usually be repaired.
If we can help, let us know.
Kirk
Ateco Engine and Dyno Shop
Elite Marine is offline
