502 magnum mpi specs >
Old 01-04-2008 | 06:03 AM
Default 502 magnum mpi specs
looking for torque curve and horsepower range for a 1998 502 magnum mpi, just seeing if any one can help, i know they are 415 hp but looking for a range at different rpm, maybe some has a dyno sheet. please thanks
JERSEY DEVIL is offline
Old 01-06-2008 | 01:03 PM
To my knowledge Mercruy never published such info.
I guess your chance is if someone have put a stock 502 on a dyno and saved the figures
Alex is offline
Old 01-06-2008 | 03:26 PM
Bruce,
I know there are different be still may be helpful to you http://www.fullthrottlemarine.com/ has dyno sheets of stock 496 on his project page.
MOBILEMERCMAN is offline
Old 01-06-2008 | 03:49 PM
Hi -
Here's an earlier thread:
http://www.offshoreonly.com/forums/a...p/t-68188.html
And this is helpful for parts, but I think your cam specs will tell the tale..the stock cam is 431-850478
http://www.marinepartsexpress.com/Me...M%20502%20V-8/
I found the attached pdf which gives you very good reason to run at WOT...but no torque curves, yet. I would suggest finding an equivalent aftermarket cam as they usually have published specs. I think Dennis Moore has a published equivalent in his book.......
File Type: pdf
nwimbush is offline
Old 01-07-2008 | 08:57 AM
Originally Posted by MOBILEMERCMAN
Bruce,
thanks jim mer won't give any info on the motor.i put the hp 500 cam in it and a set of crane roller rockers may change the computer to raise the rpm to run at 5800 just can't seem to get the engine numbers i need may have to put it on the dyno to see where i stand bruce
Old 01-07-2008 | 08:58 AM
Originally Posted by nwimbush
Hi -
thanks for all your help bruce
HiPerf2000
3
05-10-2007 09:05 PM
Smitty
10
03-11-2005 07:42 AM
Wally
3
11-23-2004 06:35 PM
shalaris
3
04-20-2004 07:24 AM
TURBOED
3
01-22-2004 10:03 PM
