Hydraulic fittings
Old 01-04-2008 | 10:13 AM
tony davis's Avatar
Default Hydraulic fittings
I'm in the process of finishing off the rigging of a boat equipped with a 4 ram latham system, and I'm trying to reduce the number of hose ends and fittings inside the transom.
Anyone know if it's possible to buy a T piece with a pair of -8 males, and a single 1/4"npt male. It would make the job so much easier.
tony davis is offline
Old 01-04-2008 | 10:16 AM
Registered User
You should be able to find that at any local Aeroquip or Parker distributor. You may have to size down from the -8 to 1/4". That's a big drop.
Chris Sunkin is offline
Old 01-04-2008 | 10:21 AM
tony davis's Avatar
We have a shortage of those in the UK! It is a big drop, but the problem is I have to have -8 to the helm and accross the inner transom because of the 4 rams, the through hull fittings are 1/4 npt, and the ram hoses are -6.
Old 01-04-2008 | 12:25 PM
Quiet Storm's Avatar
The closest I could find is use a female branch T that has the -8's and a 3/8 npt. Then a reducing nipple from 3/8 to 1/4. Parker 8OTX and 3/8x1/4 FF33S.
Quiet Storm is offline
Old 01-04-2008 | 12:33 PM
Registered User
Any reason you couldn't go to -6 bulkhead fittings for the thru-hull?
That kind of unnecesary restriction can cause slowed function and increased heat.
I missed that you are in the UK.
Old 01-05-2008 | 02:46 AM
tony davis's Avatar
Thanks for that, it's probably the only way to go.
Chris, -6 and 1/4 npt is pretty similar. Latham supplied the owner with a kit of parts, but it's incomplete. It's also a weird way of doing it. -8 x 3/8 npt adapters, 3/8 npt female tees, 3/8 npt x -6 adapters, -6 hose end, hose, -6 hose end, -6 x 1/4 npt adapter. all that just to connect from -8 supply to bulkhead fitting. Suppose it bumps up the fittings sales though!
Old 01-05-2008 | 06:49 PM
Comanche3Six's Avatar
Contact this company, if they don't have it, they can make it.
http://yellowpages.superpages.com/pr...PuQw%3D%3D.htm
Comanche3Six is offline
KN
6
04-21-2007 09:59 AM
BOB ONEIL
Cigarette
1
04-12-2006 11:54 AM
BOB ONEIL
13
04-06-2006 05:44 PM
Whiteknuckle
49
12-07-2005 07:16 PM
cooltoys61
1
04-19-2004 08:27 PM
