Best t-stat gasket sealant? >
Old 01-04-2008 | 10:20 AM
Default Best t-stat gasket sealant?
just wondering if people using sealant along with a paper t-stat gasket for a closed loop cooling system. and if so, what seems to work best for you? hope you all are having a great new year. thanks for any input
zimm1978 is offline
Old 01-04-2008 | 10:46 AM
BY U BOY's Avatar
I use a reusable gasket. Can't remember what brand but its black plastic with o rings on each side. Never had a leak. I use this on a raw water system so not sure if that helps.
BY U BOY is offline
Old 01-04-2008 | 10:54 AM
You don't need much. Mercury's Perfect Seal or just plain grease will both work. I like grease as it makes it easy to remove and re-use the gasket.
BenPerfected is offline
Old 01-04-2008 | 02:33 PM
Just plain grease on a paper gasket, hmmm i will have to give that a shot., thanks by u boy for the image, i think i'll start looking for those when the season comes around again. have a good weekend
zimm1978 is offline
Old 01-04-2008 | 02:38 PM
I use the same one by u boy uses. I like the fact I don't have to remember to buy a new one every year when I winterize.
David Stotz is offline
17
01-24-2007 07:04 AM
Danny_Ocean
2
07-05-2004 08:15 PM
US1 Fountain
Fountain
1
02-29-2004 08:19 PM
dyno
8
07-12-2002 08:34 AM
blackhawk
05-03-2002 07:31 PM
