Engine Rebuilds need advice >
Old 01-06-2008 | 06:27 PM
Default Engine Rebuilds need advice
Hi lads.
I posted about 2 months ago that I was having engine troubles with my cig top gun.
I recently imported it from the usa.
It had two new Dart M 509 blocks 650hp each.
While using them I found i had blow by and oil coming out of the breathers and super high oil pressure.
I've pulled them out and the mechanic has said I need two rebuilds, and new pistons, oil pumps, the engines to be honed and bored, rings and probably more but by that stage it became "blah blah blah blah".
Firstly, in the usa how much do engine rebuilds usually cost? HOw much are JE pistons for 509 blocks?
If I was to buy engines from the usa how much would i be up for, for similar engines? Or to buy bigger engines how much? I have no idea whatsoever on this so the more advise the better.
thanks.
priceb is offline
Old 01-06-2008 | 06:38 PM
H2Xmark's Avatar
JE piston JEP-257962-8 runs around 775.00 US dollars a set. rings extra, some speed shops will ship across the pond. not sure how much for freight though
H2Xmark is offline
Old 01-06-2008 | 06:42 PM
If i was to buy new engines with more HP, where would i look, what would you guys recommend and how much $$$$ would i be looking at.
Secondly for new legs I'd have to get new ones wouldn't i? I have bravo XR's.
priceb is offline
Old 01-06-2008 | 08:50 PM
The XR's should be ok if you treat them right. I wouldn't put any more power to them than the 650hp that you have now. Any Bravo style drive is going to pushed to its limits with 600 or more HP and your boat is heavy also.
Griff is offline
Old 01-06-2008 | 08:53 PM
GO4BROKE's Avatar
Unless they are trashed, I would imagine it would be cheaper to rebuild than replace. Lots of good manufacturers. Bullet Engines, KE, Sterling, Cobra, PRI, Pfaff, just check the links section under engine builders.
[img][/img]
GO4BROKE is offline
Old 01-06-2008 | 10:01 PM
'05 Concept SF23
Email Young Performance Marine. He is located in Tennessee
f311fr1 is offline
Ona-Mission
05-27-2008 08:37 AM
nordic95
11-24-2005 09:32 PM
ThirdBird
06-23-2005 11:05 AM
Tom
5
09-02-2002 02:28 PM
G-Force
07-24-2002 10:54 PM
