Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
how fast should this boat run with 525's? >
Old 01-10-2008 | 05:59 PM
jeff32's Avatar
Default how fast should this boat run with 525's?
I contacted the Broker.
I know what speed it apparently runs.
tell me your opinion on how fast it should run.
Then I'll tell you what speed I was told, and if I'm happy or not about the answer... do I need to tell my guess speed is not what the real speed is?
http://adcache.boattraderonline.com/6/3/7/86231837.htm
my F 35-7 has the same paint scheme so I had a little ''kick'' on the boat...
jeff32 is offline
Old 01-10-2008 | 06:24 PM
OL40SVX's Avatar
Id say this is the wrong section for this. Try the Formula section, but id say 72-74mph.
OL40SVX is offline
Old 01-10-2008 | 07:07 PM
t500hps's Avatar
21 and 42 footers
75 on a good day.......
t500hps is offline
Old 01-10-2008 | 10:13 PM
jeff32's Avatar
speed is actually more like 70 mph... honestly I wished it was more... the newer fountain 35 with 2 x 500 runs 100 mph!
hope that this older 38 with 525 would reach 80-85. so for only the 6 mph difference and the 60k more than mine, I'll keep mine! and I got the same paint scheme... so I won't really notice...but I was really disapointed...
jeff32 is offline
Old 01-10-2008 | 10:18 PM
OL40SVX's Avatar
You cant compare the Fountain to this at all. Formulas do not have a fast bottom even with the steps.
OL40SVX is offline
Old 01-10-2008 | 10:42 PM
jeff32's Avatar
I know they are different, but I thought 15 mph slower was enough! not 30 !
jeff32 is offline
Old 01-10-2008 | 10:52 PM
OL40SVX's Avatar
The formula is also a 38 so you have to compare it to a 38 fountain which is running 96mph light with 525's. The formula is ten plus year old technology and Fountain has the best hulls ever on vee bottoms. You should be comparing it to say a T/S TG which runs around 84-86 with 525's. You also have to remember that those motors are old 525sc which were only 490hp and the newer 525efi's are running around 540hp.
OL40SVX is offline
Old 01-10-2008 | 11:10 PM
jeff32's Avatar
Good to know! I did'nt know that!
jeff32 is offline
Old 01-11-2008 | 08:53 AM
No one can tell you unless you know the prop and gear ratio in the drive. The motor will turn 5450 rpms.
bryanh is offline
Old 01-11-2008 | 03:45 PM
At the risk of sounding stupid, aren't the formula hulls significantly heavier then the fountain equivalent?
Racerngr1 is offline
