NXT Drives / Trannies
Old 01-11-2008 | 06:43 PM
omerta one's Avatar
Default NXT Drives / Trannies
Tell me about your experience with the NXT's performance and durability...I do NOT want any hearsay, if you post provide the straight skinny only based on your personal experience.
JUST THE FACTS MAAM'....
BTW mine have been great so far...40 hours.
Thx!
omerta one is offline
Old 01-11-2008 | 08:19 PM
monstaaa's Avatar
from what i understand the drive itself is similiar to the 6 with the exception of having 1 vertical shaft in the lower?
but for the running part i have a bout 30 hrs on a piece with the 700 NXT packages in it and all i can say is wow. not a peep of trouble. and i assure you i was not at all remorseful on them.
monstaaa is offline
Old 01-12-2008 | 07:12 AM
Jassman's Avatar
[QUOTE=monstaaa;2403130]from what i understand the drive itself is similiar to the 6 with the exception of having 1 vertical shaft in the lower?
Thats what was explained to me also...one vs two vert. shaft.
When they came out, I had my reservations, hense my set up. I feel very differently now that more have been in service, and Nortech stated no failures on 15 plus boats. I ended up going with the #6 lowers, only for track record, I still obviously have the Nxt transom assemblies.
Jassman is offline
Old 01-12-2008 | 08:47 AM
cougarman's Avatar
Jassman,
Whats the advantage of running NXT's upper and transom assembly with a #6 lower?
Why not run the entire #6 package then?
Jon
cougarman is offline
Old 01-12-2008 | 09:07 AM
Coolerman's Avatar
PF Marine
BT just built a 46' with 700's, runs 89, handles great, and has no issues!
Coolerman is offline
Old 01-12-2008 | 09:48 AM
Comanche3Six's Avatar
Originally Posted by gramp
very good drive for 700hp power range, but for the money the #6 is a far superior drive.
Double R sells Two new in box 6A drive and transom packages for 61k. Two new in box NXT drive and transom packages for 75k. Money is not an issue when going for the superior 6A
Comanche3Six is offline
Old 01-12-2008 | 09:56 AM
northernoffshore's Avatar
I heard that shogren and the lake michigan boater were breaking nxt drives?
northernoffshore is offline
Old 01-12-2008 | 10:26 AM
omerta one's Avatar
The thread request was for personal experience...NO HEARSAY. JUST THE FACTS. Rumors are just that...and I have heard them as well, but not one from someone that actually owned or serviced an NXT; that is why I initiated this thread, to flush out any REAL problems.
Old 01-12-2008 | 11:13 AM
Thumbs up NXT Trans Questions
If you would like to call and discuss I would be more than happy to share info with you. On Fountains we run NXT transom assembly with 6 drive upper and lowers. When you go from Bravo to SSM6 or NXT the new weak link in your boat will be trans and not drive anymore. Both NXT drive and 6are great products.
Regards,
Scott Shogren
847-336-9037
www.chicagofountain.com
TeamShogren.com is offline
Old 01-12-2008 | 11:51 AM
tblrklakemo's Avatar
SeaRay Sundancer
Originally Posted by cougarman
Jassman,
Jon
you cannot run different upper and lowers....i think he means he runs the NXT transom assembly and #6 drives behind that. Just like fountain does.
tblrklakemo is offline
